Angry Clutch Problem - Need diagnosis
Hi guys,
have a 80 SC, clutch is functioning fine but the pedal has dropped by a couple of inches. So basically there is very little play.
Is this a pedal assembly issue, omega spring, or some other gremlin?
Your thoughts and advice on the possible fix would be greatly appreciated.
Jim
Old 06-27-2004, 04:40 PM
Lee Lee is offline
It might be the helper (omega) spring. It sounds like it, anyway.
Daniel Crockett
'78 SC Targa
Old 06-27-2004, 05:28 PM
Maybe your roll pin sheared in the pedal shaft
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 06-27-2004, 05:30 PM
H20911's Avatar
2nd the roll pin in pedal assembly.
Old 06-27-2004, 06:46 PM
Guys,
I have fixed the problem! Put the car up on stands and adjusted the omega spring. The travel is smooth and light and the pedal has returned to the desired position.
Thanks for the posts
Old 06-27-2004, 09:59 PM
Guys,
Old 06-27-2004, 10:40 PM
Jim Smolka's Avatar
Keep an I on the cable and the pin. Could be sign that these items are about to fail.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 06-28-2004, 01:31 AM
