porsher
aston@ultrasw.c's Avatar
Originally Posted by porschzilla View Post
Hey All,
Should I use points C&D for jacking and the jacking tubes for jack stands? Or the torsion bar caps for stands?
Jack
1988 911 Carrera Cabriolet
All the points you mention can be used for jacking or stands, use any combination you need.
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 07-09-2010, 07:48 AM
What about by the engine/trans front bracket, the one that bolts to the two holes right below "D"??
Old 07-24-2010, 04:50 PM
Under the radar
Trackrash's Avatar
There was a recent thread on this. Dual jacking my 911...
Even with this small jack I'm not jacking on the motor and the rear wheels are off the ground.
If you place a 2x6 under the motor lifting it is PROBABLY O.K. I won't do it that way on my magnesium motor.
When you consider the motor and trans are an aluminum alloy, on the newer cars, and they are held together by 4 bolts, with no mounts in the center, you may think twice about jacking the whole car there. IMO. Of course most of the "pros" jack their customer's cars that way.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-24-2010, 06:12 PM
HarryD's Avatar
This is the jacking and jack stand drawing I like the best. Has more than just the lift points.
Originally Posted by Bill Verburg View Post
X's for lifting O's(and X's for stands), there are others, the Os are almost impossible to get a jack on
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 07-24-2010, 06:47 PM
