3.2 msd install
I've gone through 50+ posts in the search, and I can't find the information I'm looking for. I understand people don't think it'll help out much, but I like to try things firsthand and formulate my own opinions. So, here's the question.
What wires do you use to control the MSD. I know that you have to splice into the DME relay wires, but which ones? I also plan on calling MSD's tech line and seeing what they have to say, and I'll post what I find and my opinions of the unit. If you're wondering about the car itself, it's a '73 with a 3.2 built to a 3.4, chip, SSI, mild cams (don't know which ones, bought it-not built it). This is my first Porsche, so far it's been awesome. |
Do you have the stock ignition? If so, I can't help... but I thin it uses a crank-fired trigger -- those are the round cylinders near the flywheel that I sold to somebody.
here's how you connect it.
large red- battery plus large black- ground white - old coil negative red (switched battery plus)- old coil positive orange & black to the coil itself i'm waiting for my new magnecors before i test it out. |
If you have a bumped chip and computer for the 3.2, the MSD is pretty much useless. In otherwords, it's not worth the hassle for the lack of gain. I've looked into it and the consensus is just this... Just some thoughts...
If you do do the MSD you'll most likely need a new custom chip mapped for the system. (I could be wrong on this one...)
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
Irrationally exuberant
If you are running the stock fuel injection (not carbs) the MSD is just extra weight. It solves a problem the stock ignition doesn't have.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Addicted to Porsche
I sucessfully installed MSD 6A to my 3.2 with motronic.
Its simple, and does not require the trigger wires. see post here: http://forums.pelicanparts.com/porsche-911-technical-forum/313547-msd6al-carrera-3-2-engine.html#post2986189
1974 911S 1990 964 C4 1998 993 Carrera S theporschaholic.com |
Thread Tools | |
Rate This Thread | |
