19 years and 17k posts...
azasadny's Avatar
My first engine drop... The madness begins!
Well, here it goes, my first engine drop. I have a fuel leak near the CIS at the top, front of the engine that I can't get to. I can't get my arms in there and I sure can't see anything with that monstrous CIS mechanism in there.. I've never dropped the engine before, but I've got Wayne's 101 Projects book and I've been reading all of the past "engine drop stories" here on the BBS. I've jacked up the car, placed my jack stands, drained the oil tank and sump, and I'm going to the store to buy a large enough wrench to remove the oil lines tomorrow. I don't have a Costco near me, but I need to get an ATV/Motorcycle jack to assist me in getting the engine safely out of the car. I'm leaving the tranny in the car and I'm thinking I should remove the rear bumper to make things easier. All of the fuel line and vacuum hoses are old and dry-rotted, so I'll be ordering them from Pelican ASAP. Any other suggestions for an "engine drop rookie"? I'm going to take alot of digital pictures during the process so I can put everything back together easier, too. Thanks!!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 07-17-2004, 07:45 PM
Licensed User
Shuie's Avatar
remove the bumper for sure.
Its not that much more difficult to drop the tranny with the motor. When I did the engine drop on my '73 I could not get to the top bolt that holds the tranny and the engine together so I went ahead and dropped them both at the same time. I used a floorjack to lower the engine/tranny and everything balanced nicely.
If you decide to drop the tranny with the engine, make sure you have a set of hex socket extensions to unbolt the CVs.
Good luck!
Old 07-17-2004, 07:59 PM
azasadny's Avatar
Sherman,
Thanks for the advice! I'm going to remove the rear bumper, but I'm going to leave the tranny in the car. I did the prep work today, the real work starts tomorrow...
Art Zasadny
www.ford.com
Old 07-17-2004, 08:06 PM
Are you sure you couldn't get away with doing a "partial drop"? It gives you several inches on top of the engine to work on fuel lines, seals, etc. You can do this by disconnecting the shift linkage, motor mounts, 14-pin connector, oil lines, then lowering the engine. You leave the trans mounts connected.
Anyway, it sounds like you're prepared. Go for it!
Old 07-17-2004, 08:25 PM
Semper drive!
rcecale's Avatar
Art,
However you do it...full or partial...just take your time and don't force ANYTHING.
Pics, from several angles, can be a valuable tool. Especially when it comes time to put it all back together. Good luck!
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 07-17-2004, 08:29 PM
azasadny's Avatar
Colin,
I may try your suggestion on the partial drop, but the fuel lines and vacuum hoses are so bad that I really want to replace all of them. I don't think I can get enough room back there unless I drop the entire engine. I'm going to take Randy's advice and take alot of pics along the way and take my time, I'm in no hurry. Thanks, guys!
Art Zasadny
www.ford.com
Old 07-17-2004, 09:53 PM
fancytown
Art--
A full drop is easy. While a engine only drop is not difficult either, a engine only install might be trying. To mate the trans and engine outside the vehicle takes ~45 seconds (2 minutes if solo). It will likely take alot longer, and involve lots of swearing in the car.
The partial drop might be good if you just want to get more access, but I vote for the "full monty". You can just see so much more, and you might see that "hidden" fuel line that could cause you trouble in the future.
I did my last drop, and re-install solo (it was only my second).
all cars sold.
Old 07-17-2004, 11:21 PM
Now in 993 land ...
aigel's Avatar
No need to take the bumper off. You can always jack the car up higher to clear the bumper once the engine and trans are on the dolly.
I'd never attempt to pull the engine only. Trying to mate the engine and trans back in the car must be very painful. Also, the access to the top bellhousing nuts is pretty limited. It really isn't much that has to come off to pull it all out together.
The ATV jack is a bad idea. When we used one on ZOANAS' engine drop, it was a pain and we ditched it in the middle of the process.
I still like a home made wooden dolly with a big slot cutout for a large regular jack. Then just lower the engine / trans on the dolly and pull the jack out from underneath.
Just my two cents. Good luck!!!
Cheers, George
81 SC (sold)
Old 07-18-2004, 02:18 AM
No ATV jack for me, just 2 good size jacks will do the trick.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 07-18-2004, 06:17 AM
Semper drive!
rcecale's Avatar
You can pick up a furniture dolly from Home Depot for $20.00. With a 1000 weight limit, it should be plenty strong enough.
Randy
One Marine's View
Old 07-18-2004, 07:10 AM
North Coast Cab's Avatar
I liked the dolly trick for my first drop as well. Also, don't go crazy jacking the car up and don't remove the bumper. Once you get the engine disconnected and all clear you can carefully jack the car the rest of the way up and slide the engine out. I'd suggest the engine/tranny in one piece as I think it's much easier to install. Finally, do a search on "while I'm in there" and you'll find a hundred other items to address.
Good luck, John
1985.5 944 GTS
Old 07-18-2004, 07:27 AM
iobound's Avatar
Send a message via AIM to iobound
Has anyone used the tool that Pelicanparts sells to hold the engine using a regular floor jack? I think its part # PEL-PW-2565. Just curious how well it works.
RPM also stands for Redhat Package Manager
16 year PCA Member
NASA Member
1988 944 NA w/4valve S motor (Daily Driver)
1992 965 Coupe 3.4 Liter, webers, GE60 (Garage Queen)
1998 Volvo V70 Wagon
2002 Barbie Electric Kids Jeep
Old 07-18-2004, 08:11 AM
350HP930's Avatar
Jack adapters work nicely, just make sure your jack has a wide wheelbase and you are on a solid surface or disaster may occur.
Click the link in my sig for a good pic of what I used to get my engine out. (My server is down at the moment so you might have to wait a while for the pics to become available)
Depending on your jack you may not be able to get the engine as low as you would on a dolly for slipping out from underneath the car.
IMHO - +1 on removing both the engine and tranny together.
Having worked in a porsche dealership I can tell you that even a couple experienced porsche techs can have a hard time getting the engine and tranny mated back together when the tranny is still in the car.
Old 07-18-2004, 08:23 AM
fancytown
Brian, I have never done an engine only drop, but my concern with it is trying to see the shift fork aligning in the throw-out bearing. There's a nice window on top of the trans to see this, which won't be visible in-vehicle. How did you know when you had it?
Also, I'm an advocate of removing the bumper. The lower my car is, the more stable it feels. Keeping everything low to the ground gave me a better sense of security. There were only a few fasteners to get my bumper off.
all cars sold.
Old 07-18-2004, 09:11 AM
Now in 993 land ...
aigel's Avatar
I am saying it must be hard to align the two, because it takes some time to mate them even OUT of the car.
I have done clutch jobs on non P cars and engine pulls and never had fun sticking the trans and engine back together. Even on front engine / rwd cars, I like to pull it all out at once. I can not imagine it is any better on the 911. But I have been wrong before!
George
81 SC (sold)
Old 07-18-2004, 10:08 AM
I might be inclined to scrap the whole CIS system when I start having problems and get tbitz EFI kit. I am waaay past the 'stock' look, anyway.
SoCal has a point in leaving it in, you never know and it might align right up. I haven't ever done a 911 drop, but plenty of other german cars. Sometimes it goes right in with a little jiggling, sometimes I fight for hours... And if it isn't working out, just drop the trans. Good point.
Old 07-18-2004, 10:33 AM
fancytown
Art--the center shaft is splined, and just make sure to turn both output shafts when aligning, otherwise the center spline won't turn. This confused me for a few minutes, until I remembered my car has an open differential.
all cars sold.
Old 07-18-2004, 10:53 AM
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
I want to defend the ATV jack, in spite of ditching it halfway through my recent drop. If we had removed the muffler prior to the drop, there would have been ample clearance, as there was when I reinstalled.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-18-2004, 10:54 AM
azasadny's Avatar
End of Day 1... progress pics
It's end of day 1 and I'm officially exhausted. My hands were all greasy, so my wife took the blurry photos. I am going to buy an ATV jack this week to do the drop. I removed the rear bumper, detached all fuel, oil, electrical and tranny connections. Wayne's book was a great help, especially with the 10mm barrel nut "not visible from any angle" above the starter, that one had me nuts! Anyway, I just cleaned up for the night and had a Hacker Pschorr Weiss bier to celebrate the work done thus far. I've never done this before and you guys have been a big help!!
This is what my family and neighbors were doing while I was in the garage!
Art Zasadny
www.ford.com
Old 07-18-2004, 06:44 PM
Oh Haha's Avatar
Good job, Art!
It feels good to get through the first drop. I did mine this winter after my Dad passed away. (Good therapy for me.)My wife couldn't help because she was caring for our just born son at the time. Don't have any friends I could call to help out so I did it all by myself from start to finish. Now I am more "in tune" with the car. Anyway, good luck and holler if you need some assistance from the board.
Wayne
Pacific Blue
Wayne
Old 07-18-2004, 07:03 PM
