UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
UPDATE-
Picked up the car today from my mech. CO adjustment AFU. Properly adjusted with gas analyzer. Purring like a kitten right now. I'll be holding my breath when I turn the key tomorrow morning.
_______________________
Racer Rix Spec911 #5
prc-racing.com
Old 07-28-2004, 05:40 PM
Doug Steinel's Avatar
It sounds like you got the problem licked. Congrats!
77 911, 3.0L
Old 07-28-2004, 05:50 PM
UFLYICU
ZOA NOM's Avatar
I sure hope so. Thanks
prc-racing.com
Old 07-28-2004, 05:54 PM
Not clear on what kind of idle hunt you had. Was it a fast hunt or a lazy slow one?
Joe
Old 07-29-2004, 11:47 AM
UFLYICU
ZOA NOM's Avatar
It was actually both at times, depending on my idle screw setting at the time. I found myself adjusting the idle screw almost all the way in when it was cold, which would significantly reduce and shorten the duration of the hunting. I'm happy to report the CO adjustment seems to have been the final piece of the puzzle. She was steady as a rock at 4am today.
Edit: the idle would vary from 600 - 1500 in a fairly quick rythym, and settle after approximately 60 seconds if left alone. If I adjusted the idle screw nearly all the way in (CW), it would recover and idle normally with 10-15 seconds.
prc-racing.com
Old 07-29-2004, 02:13 PM
I suspect you may have a very common vacuum leak to be found on 3.2's in the form of loose intake manifold nuts that allow that extra air into your engine bypassing the idle air adjustment screw causing the fast idle hunt.
Just a hunch,
Joe
Old 07-29-2004, 04:14 PM
UFLYICU
ZOA NOM's Avatar
No leak, Joe.
It turned out to be the CO adjustment. Once my mech put it on a gas analyzer, he found it was severely rich, causing the hunting idle. Once he adjusted it back to normal, it starts and runs steady as a rock, cold or hot.
prc-racing.com
Old 07-29-2004, 04:22 PM
Good to hear it was that simple!
Cheers,
Joe
Old 07-29-2004, 05:19 PM
vash's Avatar
hooray!
poof! gone
Old 07-29-2004, 05:58 PM
cantdrv55's Avatar
Let's go for a drive!
Old 07-29-2004, 07:08 PM
scottb's Avatar
Zoanas:
I had the same hunting problem in my 84, and did almost everything you did (new ICV, head temp sensor, O2 sensor, etc.). Like you, my problem turned out to be mixture. Sometimes the easiest solutions are the best.
Now, go drive!!
Scott
1984 Targa
Old 07-30-2004, 06:48 AM
UFLYICU
ZOA NOM's Avatar
Still purring...
Just a bump for others having similar problems.
prc-racing.com
Old 08-01-2004, 09:31 AM
vash's Avatar
let's lower that car!
poof! gone
Old 08-01-2004, 09:34 AM
UFLYICU
ZOA NOM's Avatar
I'm thinking the same thing, vash. I just don't have a weekend clear for a couple of weeks. I'll keep you posted.
prc-racing.com
Old 08-01-2004, 09:37 AM
cantdrv55's Avatar
Hey, I want to lower mine as well. Let us know when you're gong to tackle yours.
Old 08-01-2004, 09:08 PM
UFLYICU
ZOA NOM's Avatar
cool, here we go again!
prc-racing.com
Old 08-01-2004, 09:14 PM
WydRyd's Avatar
Hmmm, mine does a similar thing, but it's intermittent. She hunts and then stabilises, but sometimes while she hunts, she'll drop to about 400RPM's nd then stalls. Grrrr! It's annoying! I disconnected the Oxygen sensor though, so the Motronics runs the mixture richer than normal. The GT2-EVO CAMs aren't really helping either as the idle is even lumpier than when it had the stock Carrera CAMs.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-01-2004, 10:11 PM
indigowhale's Avatar
Send a message via Yahoo to indigowhale
Hey I am having the same exact problem after installing a new AFM.
Will get the CO% adjusted and report back about the hunting being cured.
I have been thru all the air leaks possible, even a new oil cap seal.
will report back but thought it good to wake up this simple-solution thread--unlike some others, where I learned a lot!
Old 10-08-2004, 01:06 PM
UFLYICU
ZOA NOM's Avatar
Still steady after all these months. Good luck, indigo, I hope it solves your problem. Hunting idle is the most frustrating problem I've had so far, but it did force me to dive in and learn some things.
prc-racing.com
Old 10-08-2004, 01:57 PM
MiamiTurbo
Does the Bently manual have this pocedure outlined? My friend has a gas analyzer, and im having a similar problem
wanabe911 owner
1974 914 2156cc project
2005 Lotus Elise Original owner
2002 996TT Tip
Old 10-14-2004, 11:14 AM
