vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Left/Right Spring Plates - Interchangable?
I am getting my spring plates cad plated and am curious if the spring plates are interchangable from side to side? - I assume not a best practice? What is the best way to mark them before going to the plater?
I will share before and after pics when I am done!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 07-27-2004, 04:13 AM
Rick Lee
Guest
Posts: n/a
I don't know how you could mix them up. I don't think they are interchangeable, even visually. I have a set of Sway Away adj. plates sitting here in my office, but don't have any stock ones handy to look at. I think there are upper and lower bolts on them.
Old 07-27-2004, 05:07 AM
jyl jyl is online now
jyl's Avatar
I vaguely recall the angle of the plate arm where it connects to the tube part distinguishes R from L. How's that for precise.
Edit: Sorry, my bad.
Old 07-27-2004, 05:13 AM
Licensed User
Shuie's Avatar
When I re-assmbled mine after plating I couldnt tell the difference between the parts that were on the RH andLH sides of the car originally. I hope I did everything correctly.
Old 07-27-2004, 05:17 AM
I would rather be driving
jpnovak's Avatar
Stock spring plates are interchangable. Both the early fixed and later adjustable. the splines may be slightly different but you will have to reindex upon installtion anyway.
Old 07-27-2004, 06:06 AM
vesnyder's Avatar
They sure looked interchangable - thanks for the clarification Jamie. I notched the passengers side just to ensure it goes back the same way.
Now if I could get them separated I could get them to the plater!
Vance
Old 07-27-2004, 06:27 AM
