Is this caliper correct?
I went to install the speedbleeders I ordered for my '75 911S. I was sent two pairs of 7x1.0mm bleeders, and they fit fine on the rear calipers.
But the front calipers have TWO bleeders each, and they are 10x1.0mm. I should have checked them first.
Question1: Is this really a stock caliper for the '75 911s?
Question2: How do I bleed them? Crack one bleeder, bleed, then close it and do the other one?
Colin
Old 07-29-2004, 10:21 PM
poorsha's Avatar
That's an "S" all right.
Why not give her a good clean up while you have it off?
I always bleed them from the outside to the inside.
Old 07-29-2004, 10:30 PM
Cowtown, I just finished the same project last night. Yes, that is the correct caliper and has two bleeders. That is an S caliper (aluminum).
Can you put my mind at ease and tell me if that is the top of the calliper in the picture. I can't remember when I took mine off if the bleeders were on the top or bottom.
1975 911 Carrera BLK/BLK
Old 07-30-2004, 06:36 AM
I would rather be driving
jpnovak's Avatar
Speed bleeders kick butt! I love them on my calipers. Open, pump, close, next.
yes you have S calipers. They require a different size bleeder screw.
Old 07-30-2004, 06:43 AM
RallyJon's Avatar
poorsha, did you get it looking that good from just a cleanup, or did you have them anodized or something?
993 · 911 · STI · S4 · rally car
Old 07-30-2004, 06:47 AM
poorsha's Avatar
RallyJon,
"spit and polish" (and some Simple Green).
I also installed the Stainless pistons.
I am amazed at the condition of everything on my 74 (except for the paint). Not a single frozen nut or bolt.
The brake backing plates cleaned up the same way (they are out for plating along with just about everything else).I am taking a lot of pics.
78 911SC sunroof Coupe (SOLD)
97 328i Convertible
Old 07-30-2004, 06:54 AM
Poorsha,
Can you confirm which is the top of the caliper. Do the bleed screws go on top?
Old 07-30-2004, 07:00 AM
poorsha's Avatar
They are on the top.
97 328i Convertible
Old 07-30-2004, 07:10 AM
Thanks you guys. These "S" calipers are so much nicer than the ones on my old '88 that they confused me. The '88 Carrera had a big heavy steel caliper with one bleeder.
These are so light and good lookin'!
Colin
Old 07-30-2004, 08:08 AM
vash's Avatar
poorsha, that caliper is stunning. i think the bleeders are on the top to let the air bubbles that float a easy way out.
do speed bleeders make the motive power bleeder obsolete? or redundant?
poof! gone
Old 07-30-2004, 10:59 PM
poorsha's Avatar
Thanks vash.
Nothing goes back on without a good cleaning.
97 328i Convertible
Old 07-30-2004, 11:07 PM
