warpspd's Avatar
Send a message via ICQ to warpspd
3.6 conversion electrical question
I am getting down to the last few things on my 3.6 conversion
and wanted to ask the guru's on the board a few electrical
questions on the conversion. First I am putting a 95 3.6 in
a 76 3.0 carrera. This is where I am at so far.
On the 14 pin female connecter on engine harness:
Moved pin 12 to pin 14
Took out pin 10 and insulated it
Took pin 3 (resistor blower) yel/blk out and insulated
Moved pin 14 grn/blk (oil temp sender) to pin 3
On the 14 pin male engine bay connector I was
going to take pin 9 (tach wire) out and swap in the
grn/red oil pressure switch wire but I could not find
it on the harness.
Am I doing this thing right?
Here are some pics....
Ryan
Cimarron region PCA member
98 Boxster
Old 07-30-2004, 11:04 AM
Bill Verburg's Avatar
Did you get the instruction set from Steve T. He has all the changes listed there, if not he put the 993 in my C3 last year and likely noted the changes needed.
Bill Verburg
Old 07-30-2004, 01:00 PM
