LinkBack Thread Tools Rating: Thread Rating: 15 votes, 4.47 average.
kuehl's Avatar
Phillip,
with the 78-89 930's, with half deck lid condensers, we use a 9" fan, simply bolted onto the unit and the gains are worth the investment (lower high side pressures = lower vent temps), however on the non-turbos' the story is pretty much as we have outlined.
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 07-11-2005, 11:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
Charlie, thanks for the clarification on the front floor vent. I'll look for it. Vents seem to be venting uniformly and strongly, but I'll check the ductwork to see if anything is amiss.
'02 330i Steel Grey daily driver 185k miles.
'06 Cayenne Turbo (former)
'99 Carrera Coupe. Zenith blue manual. (former)
'86 Carrera Targa Prussian blue (former)
'06 Range Rover Sport - Wife's car. Tonga green. Like few others...
Old 07-11-2005, 01:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
kuehl's Avatar
Randal,
On the 86-89's, turn on your vent air (right hand console control).
Turn the thumb wheel on the side vents to full open. Check to see if the amount of air coming out "feels" the same on both sides. You know you have a hose problem when you can feel cold air blowing out from under the dash by the cover for the heater booster motor.
Kuehl
Old 07-11-2005, 01:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
Location: Rehoboth Beach, DE summer - Indian Wells, CA winter
I have had a large fan attached to the deck lid condensor for over a year. It has helped with cooling but has not affected engine temps at all. I have driven in 95 degree rush hour traffic and 95 MPH runs to SC with no increase in engine temps.
Old 07-12-2005, 12:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
Cool (no pun intended). I hope for the same result.
Phil
89 930 Slate Grey/Black
K27 B+B 1 Bar
shaved gutters
backdated to opening vent windows
Old 07-12-2005, 01:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
kuehl's Avatar
its "Kuehl" not cool.
I've seen the subject title on this thread for awhile now, think its time to post the dimensions, brcorp ?
Kuehl
Old 07-12-2005, 02:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
The moment I've been waiting for.....
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 07-13-2005, 02:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
kuehl's Avatar
rearward Kuehl unit, 13x12.5x1 nominal inches, serpentine design.
forward Duehl Kuehl unti, 9x12x1 nominal inches, serpentine design,
You owe me!
Kuehl
Old 07-13-2005, 02:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
Amen
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 07-13-2005, 06:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
scottb, I was looking at the photo of your front fender design again, and got to wondering about your stone guard placement (assuming you added one), and whether you were able to position it far enough away to allow airflow through the condenser. Or whether you fabricated some kind of louvered cover, like the oil cooler cover on the passenger side?
I'm thinking that having the coils parallel (rather than perpendicular) to the car might allow better air flow, allow a wider (bigger) condenser, and that the stoneguard wouldn't interfere with the air flow, since it need only protect the side of the assembly. On the other hand, the condenser/fan assembly oriented that way would have to be thin enough to have venting room on the condenser side.
How did it work out for you?
Old 07-14-2005, 07:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
kuehl's Avatar
ac condenser tubes "should" run parallel or perpendicular to gravity, and gas side should start at the top and the liquid side should exit out the bottom
Kuehl
Old 07-14-2005, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
"parallel AND perpendicular" ??
Oops.
"parallel to the ground and perpendicular to gravity"
Old 07-14-2005, 09:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
scottb's Avatar
Randal: I made my stone guard out of sprung steel. So, to answer your question, airflow is fine. So far, I'm very happy with the improvement. It's a neat, clean installation, and my vent temps are in the 30s.
Scott
1984 Targa
Old 07-14-2005, 09:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
kuehl's Avatar
Thanks Brian,
I never finished that first cup of coffee before I hit submit.
By the way, which way is gravity?
Old 07-17-2005, 07:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
Dunno. I figure Newton's apple leads the way!
Old 07-17-2005, 04:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
Scott - thanks. You mentioned you are inland SoCal. Are you getting any of this 115 deg crap that we're getting in Phoenix? If so, just wondering if you are still seeing 30's out of the vents. If so, that's the approach I'll take. At least as a first step...
Old 07-17-2005, 04:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
scottb's Avatar
When it's this hot, I drive the Lexus!
1984 Targa
Old 07-17-2005, 10:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
kuehl's Avatar
Scott,
When its that hot your suppose to open all the window and drive fast!
Kuehl
Old 07-18-2005, 01:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
I thought Lexi were worn not driven...
Old 07-21-2005, 05:32 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
Scott,
Any thoughts as to the relative effectiveness of the left front fender condenser you installed as opposed to the duehl-kuehl condenser from Charlie. ("Kuehl, if you are on line, please chime in?)
I'm still intrigued byt the fact that in our MB I get vent temps at 50 degrees but am NEVER uncomfortable since I get a lot of air movement from the vents. Go figure...
Old 07-21-2005, 07:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
