bigrubberjeep's Avatar
Ignorant question, but I go to ask!
Why did the 3.0 engine have more power then the 3.2 engine
Please break it down for me in basic terms.
I don't understand why with so many mods for the 3.2 it basicly only puts out about 260HP if your lucky, yet the 3.0 RSR engine(or RS, im not sure) puts out about 240 stock?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 08-10-2004, 10:30 AM
Chuck Moreland's Avatar
Specifically what engines are you comparing?
A stock 3.2 is rated at 215. Stock 3.0 190.
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-10-2004, 10:38 AM
You're comparing a 3.0 RSR race engine with a stock production 3.2 w/ full emissions equipment. Of course the race engine would put out more hp.
Old 08-10-2004, 10:48 AM
Honestly guys, I don't know what I am talking about. I read it in some Porsche book that a RSR 3.0 motor put out over 240HP I just cant recal where. What Noah said makes sence though. High RPM.
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Compression, Cams, lightweight/balanced/hardened (exotic material) hardware capable of much higher rpms, larger....valves/manifold(s), enhanced fuel delivery.........
Warren & Ron, may you rest in Peace.
Old 08-10-2004, 10:52 AM
Administrator
Jack Olsen's Avatar
A 180-hp factory SC motor will last 200,000 miles or so.
A 3.0 race motor putting out 240 hp would have a between-rebuild lifespan measured in hours. If you had one, you'd need a tolerance for its difficulty idling, a budget for the regular rebuilds, and a map with the gas stations in your area that sold 100-octane gas.
You can make a great race motor out of a 3.2, as well. But if longevity and useability are important to you, you don't simply go for the maximum peak horsepower.
Old 08-10-2004, 12:04 PM
Unregistered
sammyg2's Avatar
Apples to oranges, but ponder me this:
On a full out high revving race engine where money is no cost, bore/stroke ratio is a big issue.
The 3.0 has a larger bore/stroke ratio due to the 3.2 having a longer stroke. The longer stroke generally makes more torque but may not rev quite as quickly = hp. (I know this is an incredible over-simplification, but there is some basis to it).
Now if you take a 3.0 and over-bore it to 3.2 you get the best of both worlds, quck revving and displacement.
Anyone know what the bore and stroke of that 3.0 RSR engine was?
Old 08-10-2004, 12:05 PM
95 x 70.4.....
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-10-2004, 01:18 PM
Registered abUser
TerryH's Avatar
The stock 81-83 RoW SC does put out 204 HP without giving up reliability, but that's still tame compared to 240 HP. As you get into bigger HP numbers the stress on the motor rises exponentially.
'81 911SC Coupe SOLD
Old 08-10-2004, 08:20 PM
