LinkBack Thread Tools Rating: Thread Rating: 11 votes, 4.64 average.
Automotive Monomaniac
Emission's Avatar
Cat is original. 131,000 on the car. All of the other numbers are well within range. The "smog tech" says the cat isn't suspect - it's running too rich.
In all honesty, I want my turbo to run rich. I just don't want it rich during the smog test!
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 08-11-2004, 11:46 AM
avendlerdp's Avatar
If the O2 is new, then mixture change is for you! Get a 3mm allen and bend it to clear the top if the engine compartment and try an 1/8 turn at a time.
Alex
1972 Porsche 914 Project
2000 BMW M5
1973 Aermacchi 350
Old 08-11-2004, 11:54 AM
clnilsen's Avatar
Dude, I feel your Pain
I just took my 911 SC in to e-chump today, and while the emissions passed in flying colors, the car failed the stupid GAS CAP leak inspection. I was suprised, since they have never been able to test this before, but i have dutifully ordered my new gas cap, with second day to Ohio.
Wankers.
Chuck
1980 911 SC Targa *Sold!*
2003 Boxster
2013 Beetle Turbo cab
Old 08-11-2004, 12:48 PM
Emission, do you have a cam in that 930? What other Mods? I purchased my 930 a year ago w / all kinds of mods on it, didn't know it at the time. It passed the smog test fine. As I read the posts, I am so afraid and am pissing in my pants. one more year to enjoy it. Jeff
Old 08-12-2004, 02:24 AM
Emission's Avatar
My mechanical mods are limited to a larger turbo (K-27) and a wastegate dump pipe. Neither should change smog readings.
With a recent tune & valve adjustment, new cap, rotor, plugs, and new O2 sensor... my issue is mixture. I am running too rich.
I wouldn't worry until you see the words FAIL on the screen.
Old 08-12-2004, 07:59 AM
Designer King
Paulporsche's Avatar
Emission,
I have advised posters to lean their mixture many times. Since you are already at .81% CO and only have to get down to .61 I am concerned because that is both extremely low, and a very small amount of a change. It seems that 1/8 of a turn on the screw is worth about 1% so I would just nudge that screw down just a little. A Gunson Gastester is only accurate to .5% so I don't think one will help you.
Also, get that CO back up to the sweet spot ASAP after the test. .61% sounds absurdly lean to me.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-12-2004, 03:32 PM
Unregistered
sammyg2's Avatar
OK, question time:
since his mixture is controlled by the lambda circuit, how is adjusting the mixture slightly going to change anything? Am I missing the boat?
Seems to me that unless you disconnect the O2 sensor or lean the adjustment out so far that the frequency valve goes out of range you aren't going to change anything except the mixture before the O2 sensor heats up and kicks in. I need to scratch my head on this one.
Old 08-12-2004, 03:56 PM
kbruz's Avatar
I had lots of problems with independent smog shops. Same with my wifes BWM. We ended up going to an independent shop that specializes in german cars.... no more problems. pass everytime. I really think that the smog only shops just don't know how to deal with german cars..
kb
mercedes GLK350
2009 boxster s
86 targa
Old 08-12-2004, 08:03 PM
Registered abUser
TerryH's Avatar
"Test Only" stamped atop your registration usually means you don't get to go to your favorite shop for certification. However, my car went to my mechanic to pretest, he set the A/F, then it went to the test only station.
A few extra bucks, sure, but small potatoes to get past this stressful time.
'81 911SC Coupe SOLD
Old 08-12-2004, 09:40 PM
I just had my smog done this weekend and was very scared. I had to travel down to Woodland Hills to my regular guy as I passed before. Check out my results:
15 mph
CO2 14.1
O2 0.00
HC 47
CO .53
NO 783
25
CO2 14.1
O2 0.00
HC 90
CO .53
NO 848
Old 08-12-2004, 10:34 PM
Emission's Avatar
cab83_750, what gear? Second both times? What RPM for each?
Congratulations on passing!
Old 08-12-2004, 10:36 PM
Not sure! I suspect he did something funny as my RPM ranges are:
15 mph 2,533
25 2,385
What RPM readings do u have?
Old 08-12-2004, 11:04 PM
Emission,
Remember a few months back when you were mocking me for you bought the 930 I was looking for!!!!!! That's karma (sp?) for you!!!!
BWAH! HAR! HAR1
Just kidding man. I loved your car. Hope you pass next time around.
Old 08-12-2004, 11:07 PM
Emission's Avatar
15 mph in 1st @ 1959 RPM
25 mph in 2nd @ 1939 RPM
Having a tall 4-speed sucks for this test.
I never drive the car at such a low RPM. I'm not in the mood to deal with it this weekend, so next week I'll work on the mixture and get it tested again - and pass, of course.
Oh, after I pass I'll rig a device to pump diesel fuel into the exhaust (like those acrobatic planes) and leave white contrails as I drive by each DMV.... yahoooooo.......
Old 08-12-2004, 11:13 PM
But that's after the cat, remember. Before the cat it may be as high as 2%.
So how can that be so absurdly lean?
Joe
Old 08-13-2004, 04:52 AM
TedSlick's Avatar
Emission, we both failed CA smog this week. Turns out in my case the oxygen sensor was indeed bad. Replaced it with the universal type and the improvement was dramatic.
I posted the latest results in the first post of this thread:
CA SMOG test failure and unexpected results...HELP :(
Are you sure your new oxy sensor is connected properly?
Old 08-13-2004, 07:43 AM
Emission's Avatar
Originally posted by TedSlick
"Are you sure your new oxy sensor is connected properly?"
You just planted a seed of doubt.
My new 02 sensor is in-line with a new air/fuel mixture reading device (spliced off the same wire). The 02 sensor is in, but I still haven't hooked up the device (loose wire right now). When I hook it up, it will confirm operation of the 02 sensor.
Once again, too lazy for a "this weekend" project. Maybe Monday night...
Old 08-13-2004, 09:30 AM
Designer King
stlrj,
Good point. I forgot about the cat. I don't have/need one on my car here in Ontario.
BTW do you know:
1 Were these cars required to run @ .61 back when new?
2 Is a rise from .61 to about 2 % typical for after cat versus pre cat measurements?
sammyg2,
I think what we who were advocating leaning the mixture were thinking was that, since the O2 sensor was working correctly (which now may not be correct) then leaning by turning the mixture screw may bring the CO down. I'm thinking that maybe even something like a WUR could be slightly off, which could also be adjusted, if reqd. All this as long as everything else is OK...frequency valve, thermoswitch, cold start injector not leaking, etc. etc,etc.
Paul
Old 08-13-2004, 11:24 AM
Paul,
I believe 0.61% is an allowable maximum as the cat ages and losses its effectiveness. If the cat were new, the CO at the tailpipe would most likely be so low as to be hardly measureable.
Joe
Old 08-13-2004, 08:49 PM
Fuchs w h o r e
The problem is your CAT. They don't last forever, and 18 years is unusually long.
Even with the way its tuned now, you should expect to see results of less than .02%CO and 5ppm of HC with a new CAT.
Old 08-16-2004, 12:10 AM
