Send a message via AIM to jasonporsche Send a message via Yahoo to jasonporsche
speedometer issues
hi everyone, got my 87 911 carrera. The problem i hacve is like the speedometer is sticking. if i come to a stop and then go up to about 20 miles per hour or so, basically when i'm just normal driving and shift to second, the needle starts to read and then reads normal. Anyone ever seen this problem. Is there anything to do short of replacing the gauge. I would like to fix it if anyone has a quick fix. It bothers me, but not enough to reaplce the gauge.lol
Jason Gautney
87 3.2 coupe
Old 08-16-2004, 11:10 AM
Designer King
Paulporsche's Avatar
Check and clean all the electrical connections. If that doesn't do it, do a search. There is info on gears that can be replaced and on the connection at the transmission.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-16-2004, 12:58 PM
It's probably the magnetic sending unit that attaches to the outside of the transmission case...held on by a small clip. If I recall correctly, it does not penetrate the trans case but simply gets inductive pulses from inside ( via magnets).
Replace the sending unit...I have the same issue on my 85 ( 915 trans) that uses a similar arrangement. No speed indication until 20 mph and then it jumps up tp 20 mph+ and continues normally. I have the part but haven't yet installed it.
-- Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-16-2004, 01:21 PM
I'm not a speedo expert but at least the 87 speedos have a history of being defective. Mine was replaced by the original owner at only 4k miles. The replacement one still works (100k miles now) but it does occasionally bounce around a tad. Is yours the original?
-Steve
'87 Carrera Targa
Old 08-16-2004, 01:24 PM
honestly, i'm not sure. I do believe it is thoughy. so the 87's had a problem with this?
Jason Gautney
87 3.2 coupe
Old 08-16-2004, 04:38 PM
I have the same problem......similar 87 carrera.
was told it might be the sender or the signal wire going into the speedo. Someone also mentioned abt a loose connection at the fuse box. Any can tell me where in the fuse box is the speedo fuse?
Thks
Old 08-17-2004, 01:39 AM
Racer
preston_brown's Avatar
I too have the same problem. From stop, the speedometer often sticks until you hit 30 mph or so.
One data point to add: I can always "jiggle" the needle off of rest/zero by giving the front of the gauge a slight tap with my fingernail. Therefore, I think the issue is a mechanical one rather than an electrical one. Definitely on the gauge end, and nothing to do with the sender on the transmission.
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 08-17-2004, 08:35 PM
a member once posted that his speedo glass was installed backwards and it caused the needle to come in contact with the glass..
It may be plastic instead of glass.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-17-2004, 09:04 PM
