CIS basic mixture adjustment
I have just finished reading the Bosch Fuel Injection & Engine Management by Charles Probst. My question is the difference in setting the basic mixture adjustment without the gas analyzer: the K-Jetronic with Lambda is recommended to use a dwell meter connected to the test connector to a target of 45 to 55% whereas the Motronic is set (again, if no gas analyzer is available) by hooking up a voltmeter to the disconnected Oxygen Sensor and adjusting the 3mm screw until finding the midpoint between the lowest and highest sensor output which is about 500 mV. I realize the best method is with the gas analyzer but that is not currently in my budget. The target should be so that open loop and closed loop are the same value. Can the latter method (Motronic) be successfully utilized when attempting to set the basic fuel mixture in a 911SC?
Daryl G. 1981 911 SC - sold 06/29/12 |
Unregistered
Yes, it can. I do just that, but with an air fuel ratio meter.
No, it isn't as accurate as a wide band, but it will get you in the range. |
O2 Sensor Voltmeter Values?
I used this method just yesterday with great results.
I Found these specs on the internet ![]() I used a fluke meter reading millivolts and read the o2 sensor. I adjusted the mixture and set mine to 865mV. I don't know how accurate this is but my car idles very smooth and revs all the way to the way to 6k with no backfires, pops or anything. Scott
Scott Sharp 83 911 SC Guards Red 95 Honda Accord V6 |
Scott
Sent you a PM
----------------------------- Ernie 81 SC |
sub'd
Shane - 1984 928S |
