Cab Window Seal Replacement
Anyone replaced those vertical seals at the back of the side windows on a carrera cab? They seem to get pretty worn out looking from sun & weather and it would spruce up the car considerably to replace them.
I've done a search - but can find no discussion on this subject.
Any pointers on this?
Old 08-27-2004, 07:49 AM
For future reference of those performing a search under this topic...
The swap is a 10 minute job per side. No glue required. The seals sit inside of a steel frame that is secured to the edge of the cab top. Simply remove the four small nuts from the inside. I found a couple of them easier to get at with the top half way open.
Once the nuts are removed the frame will still be held in place with speed-nuts (small, thin guage threaded washers). Unless you are much more talented than me, you will need to pry the metal frame and seal away from the cab top - destroying the speed nuts in the process. I don't know how you would remove the speed-nuts otherwise. You will need to replace these with new speed-nuts - or do like me and use small washers instead.
Secure the new seal to the frame - reposition and resecure the frame to cab top with your new washers/speed-nuts and nuts.
Old 08-28-2004, 02:53 PM
Used Up User
imcarthur's Avatar
Do you feel like you're talking to yourself?
My new cab needs these & I was wondering what was involved.
Thanks for the info . . .
Ian
'87 Carrera Cab
Old 08-28-2004, 03:33 PM
Thanks for putting the detail info in, nothing is more irritating than finding a post with the exact problem you're having but they never update w/ the resolution, and it's 4 months later.
From one Cab owner to another, thanks,
Bill W.
Bill W.
'97 Arena Red / Gray 993 Cab
'93 968 Coupe 6 Spd
'88 911 Cab Red/Blk (sold)
Old 08-29-2004, 04:58 PM
Used Up User
imcarthur's Avatar
Well the only problem is the cost:
$152.55 + $148.50 = $301.05 (via our hosts)
It ain't a cheap job.
Ian
'87 Carrera Cab
Old 08-29-2004, 05:24 PM
