safe's Avatar
I have been thinking of a setup like this.
Definitely subscribing
Magnus
Old 03-12-2007, 02:24 PM
I picked up a complete dual plug Tec 1 setup for a very good price, so I will be using that. I was think MS, but then this system came up, and it was very close to the MS cost once you added the sensors, and ignition components.
I will replace the washers with spacers, the standoffs for the fuel rail that were on the TB are long enough and the right sizing.
For injectors I am using a set of Acura/Honda injectors, they are the correct size to fit the bungs on the TB's as long as you use the Suzuki o-rings. And I picked up a complete set on e-bay for $130.00, they are available in just about any size you want as the Honda crowd is forever replacing, up-sizing as they turbo/NOS their motors. Quite often almost brand new from a blown motor
I am going to try the throttle position sensor that is built into one of the throttle bodys, it is a three wire, and seems to be within the same range of resistance as the Bosch one I got with the TEC unit.
Just filled in the holes left when I removed the upper throttle plates with JB weld. Once it is dried I will sand and polish it down. Then onto fabbing some linkage arms.
Oh, and one of the manifolds I bought was from a sportamatic so it was drilled and tapped for vacuum fittings on 2 of the runners, I did the same to the other as the standoffs are there, just not dilled through, just need to drill at an angle into the manifold.. That will be my vacuum source for the MAP sensor.
The thottle bodys have vacuum ports as well, but I am going to use those for Idle Air as the are located directly under the throttle plates.
Robert
Currently Porsche less (but the wife has 2)
Old 03-12-2007, 03:40 PM
Ports in manifolds
Ports in TB
Throttle Position sensor
Robert
Old 03-12-2007, 04:05 PM
Update.
I have fabbed up the throttle linkage
Robert
Old 04-03-2007, 03:11 PM
and fuel injector rails.
I may need to play with the length of the linkage arms but I made them extra long so I can try different hole positions to match the butterfly movement to throttle positions, but I do have a full range at the moment. I just mounted everything on the motor for mockup purposes and stuck a set of air horms on top to see what it would look like.
Next step, create the wiring loom for the injectors. Then pull the existing motor out of the car, put in the return fuel line, pump, filter and pressure regulator and insert new motor. Just need it to warm up enough around here to be able to work in the unheated shop on the car.
Robert
Old 04-03-2007, 03:18 PM
sammygon1's Avatar
We need an update!!!!!
Sam Gonzales
'69 912 2.0 -6 power
Old 08-08-2007, 07:07 PM
SCWDP911's Avatar
sub'd Need to read the rest of this one...
Shane
- 1984 928S
Old 08-08-2007, 07:23 PM
FenderGuy's Avatar
this is a great project
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 08-08-2007, 09:17 PM
subscribed
Earlysport
_____________________________________
69 911E, 69 911E RS Rep 3.0L Hotrod, 77 930
IROC REP 3.6L SOLD, 968CS SOLD, 987 Boxster S SOLD
Old 08-09-2007, 12:19 AM
Sorry no progress, the summer has been taken up with house work, not cars. And I am off to Italy for 4 weeks in a few days. I figure that I will be getting back to the car this fall. Not to mention that with all the delays I am not going to be trying this out on my old 2.4 first, rather I will be building up my HO 2.7 and installing on that. So most likely there will be no updates until late in the year. But I will post when I do further work.
Robert
Old 08-09-2007, 07:03 AM
shbop's Avatar
subscribing
Jon
Old 09-29-2007, 08:39 AM
jmz jmz is online now
jmz's Avatar
sub
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 09-29-2007, 09:11 AM
SZH SZH is offline
Alberg37Yawl
Originally Posted by jmz View Post
sub
JMZ
Would you please send me details ,price and some pictures on your A37 Yawl.My e-mail adderss is szhart@sympatico.ca
Thank you and best regards
Steve Hart
Old 10-09-2007, 07:00 PM
jmz's Avatar
email sent.
Old 10-10-2007, 06:11 AM
meister member
speedracing944's Avatar
Subscribing as I am looking at adapting a set of GSX1300R Hayabusa throttle bodies and Mega Squirt II to my '87 944 S.
Keep up the good work and keep us posted.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 10-14-2007, 02:50 PM
safe's Avatar
Now I'm on a similar route, I have bought throttle bodies from a Suzuki TL1000s (1000cc V-twin) for my 3.2 motor .
They are maybe a tad to big at 48 mm, but they where available and cheap, and that makes up quite a lot in my book (read wallet).
Being a big v-twin at 125hp, I think I can use the injectors and that makes it even cheaper.
When I figure out how to mount them I'll post some pictures.
Magnus
Old 11-07-2007, 07:13 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Safe,
I cant wait for your results...and updates on this one...
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 11-07-2007, 02:16 PM
safe's Avatar
Time to post some pictures I think.
As I posted earlier I found some throttle bodies from 3 Suzuki TS-1000.
It's a 125 hp 1000cc v-twin bike.
The throttle bodies, as they came. Note the left and right (actually front and rear) body are not exactly the same. The left has the throttle cable "thing" and the right has a TPS, internally they are the same.
Disassembled
The lower part of the body was a little offset, so I had to be creative with the manifold. The flange was cut out on a water jet.
Had a flange cut out with the 3.2 plastic spacer as a template.
The pipe between the flanges a just a common exhaust pipe that I cut up and welded back together to get the taper to match the port. Don't laugh at my welds I'm a newbie!
Finished! Later I had someone who I handy with a TIG to weld up the pipe to the flanges (not shown in this picture).
All six fitted to the engine.
Next job is to make some sort of linkage to connect the 3 bodies on each bank to each other. Not sure how to do this yet, my original plan failed, but I have a backup that I will try this weekend if I get the time.
When that is done I will use a cable set up from each bank to a bracket and connect them to the stock bell crank on top of the engine.
Using cables I will be utilizing the progressive throttle opening feature on the throttle bodies.
Magnus
Old 02-01-2008, 09:55 AM
AutoBahned
RWebb's Avatar
Fabulous - whatever you do, do NOT keep track of the hours you put into this project...
Old 02-01-2008, 03:30 PM
SCWDP911's Avatar
Man, this is looking so awesome. Great work. On your stacks, if you really wanted to snaz them up, maybe you could find a good machinist to get a jig set up on a lathe so you could take the rough edges off and then sand and polish. But then again, who cares, they look great the way they are... Nice work!
Shane
- 1984 928S
Old 02-01-2008, 04:08 PM
