Guest
Posts: n/a
Another RS project. MINE part 4
I just got my Linsey8,9.5x17 in an RS finish. They look so cool! I wanted to finish the car for the German Auto Fest but could not. There are to many little things to do that require thousands of dollars so The Toad is just going to have to wait.
Anyway, I thought I would share so pics of the wheels. Enjoy! ![]() ![]() ![]() ![]() ![]() ![]() |
Administrator
Thoser are both beautiful... and evil.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Guest
Posts: n/a
Thanks Jack! The yellow paint from my house is reflecting on them and give the wheels a yellow tint.
Gorgeous - you won't be able to drive the car...
What are Linsey's? Do they refinish Fuchs? Or are these copies of a Fuchs? IF the latter, are they forged? |
Administrator
They weld a Fuchs center into a single piece outer rim. It's a great way to get custom bakspacing, 17-inch diameter, and that old-time Fuchs look. As a bonus, the wheels are lighter than the same width of Fuchs.
Guest
Posts: n/a
Thanks Jack. Here are a couple of pics from the back side. They use a real 16x6 donor wheel.
Guest
Posts: n/a
Oops!
Guest
Posts: n/a
[QUOTE]Originally posted by Randy Webb
[B]Gorgeous - you won't be able to drive the car... Drive it! I cant wait to track the ***** out of it! |
But that would get the nice wheels all ugly!
When are you gong to post the pics of the new Wevo brakes you are about to buy and test out for us? |
Guest
Posts: n/a
Maybe! There is something missing from this picture.
Those look darn good Joe. The wevo brakes at the show were just gorgeous, their quality is amazing and they fit under 15's!!!! too cool, so who in socal is gonna have em first? haha, what tires are you going to run on those??
74 911s neverending story. two feet and a jetta for now. |
Guest
Posts: n/a
Zombie
911 361 020. I think they were 7x16 Fuchs.
Do you have more info about the last pic ?
Timo 914-6 |
Beautiful
![]() Did you supply a donor set? How much? If you don't mind me asking.
"Understeer is the sign of the Devil" 1989 911 Carrera Targa (Black) 2001 Jaguar XKR (Silver) |
Guest
Posts: n/a
Yes. The wevo brake system was gorgeous! Very pricy i'm sure. I could think of alot better ways to spend that kinda money on the project. For right now at least. When its done and i'm bored, I may look into it. I also liked the way iy fit under a 15 wheel. Very trick!
![]() Mark and 914timo, I did not supply the donors. Mike Linsey did. Final cost was 2100.00 Alot cheaper than 951, 8x16 and 911, 9x16. Then add the cost of restoring. I dont know the part #'s for fuchs, but I thought that they were 16x6 because they are flatter on the outer section. |
Looks like your car is almost ready to roll. What still needs to be finished?
Anyone have a ball park price on the Wevo brakes?
72T RS look 96 993 |
Guest
Posts: n/a
[QUOTE]Originally posted by Az911
[B]Looks like your car is almost ready to roll. What still needs to be finished? The rear suspesion needs to be installed. All 4 calipers need to be rebuilt, SS brake lines, headliner and RS carpet kit installed, Tired 2.4 needs to be cleaned up before I install it, chrome needs to be sent out and polished, tires, install a TRE ST rollbar, seats, harness, and a couple of little things. I kinda of put the car on the back burner as I need to concentrate on work right now. How is your car coming along? |
nice rims. That car is gonna be smokin'!
...back to Wevo... what makes their brakes so special? (Other than 4 pistons) If it's in the price range of 930 brakes, why go w/ Wevo? Once we go that route (putting ANY caliper under the p-car), does that mean that as long as the mounting bolts line up, AND we match the piston size to the master cylinder, that any caliper will do? The reason I mention this is b/c Wilwoods are dirt cheap. I know they have a Nascar association, but as far as calipers go, they are not bad, considering what you will be replacing. They've improved greatly and even the low low-end models drastically reduced caliper flex. |
Thread Tools | |
Rate This Thread | |
