Dynamat in Engine Compartment
Has anyone used Dynamat in the engine compartment
in place of the foam pad the factory uses ?
I am looking for a way to clean up the engine compartment
and the sound pad is an eyesore. What about the
foil and felt pad that Performance and MidAmerica sells ?
Chuck
Old 09-28-2004, 07:36 AM
Re: Dynamat in Engine Compartment
yes
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2004, 07:55 AM
Ronin,
How well does it work... how does it look ?
Do the ends fold down like the factory foam pad ?
Do you think you have more room in the engine compartment ?
Can you tell a difference in the sound inside the car ?
Thanks for your input
Chuck
Old 09-28-2004, 09:29 AM
MuffinMan's Avatar
Pelican sells a silvery engine pad replacement, made by Appbiz. There are a bunch of testimonials on the site to that product.
Rob Fusi
77 911S | 3.6 Varioram | Triad Muffler | B&B 9400 Cooler |WEVO everything | Big Reds | 23/33 | 22/22 sways | Polybronze | RSR shocks/struts | FM10s |
GTC Motorsports
Old 09-28-2004, 10:06 AM
Bill Verburg's Avatar
I have Dynomat also, it works and looks fine
What little can be seen anyway
This is a sister to mine, also w/ Dynamat
The AppBiz one also works well
Bill Verburg
Old 09-28-2004, 11:55 AM
Ronin,
ditto, ditto, ditto Bill & Muffinman
I've used a lot of Dynomat in various places, so maybe I'm not the best example.
My act was to kill the tin can sound thus making the exhaust sound and audio much nicer.
There is also a very good Dynamat style lining called B-Quiet that's cheaper. Randy Webb has posted good audio sound deadner info fyi. Maybe search Randy's name and audio, Dynamat, etc.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2004, 12:25 PM
Me like track days
Craig 930 RS's Avatar
APPBIZ = very light and well made (can even get the edges finished - in colors no less)
Have one in the SC with 3.6 conversion
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-28-2004, 12:48 PM
Randy Webb's Avatar
My interest was in using the lightest wt. sound "deadener" - BUT not for the engine pads as shown above. I just used a new stock pad. It's light, already cut to fit, and obviously works. I don't see anything wrong with the alternatives above. Radiant heat will be reflected back onto the engine (until the shiny color is ocved with soot, dirt, grease, etc.) but I doubt this is significant. It's an experiment tho - and doesn't seem to have any adv. or save any $$ over the stock pad. Note - the ones sold now are lighter and more ong lasting thatn the ones that came on 1970's 911s.
Old 09-28-2004, 01:07 PM
