Calculating torque
I just dropped my axles to repair torn CV boots. I had purchased a 3/4" breaker bar and had no problems getting the axle nut off. Now for putting them back on and torqueing them up to spec. I need to get 217-231 ft-lbs of torque but don't have a wrench that goes that high. I can purchase a 3/4" torque wrench from harbor freight that goes 100-600 ft-lbs for about $70. I can't think of too many fasteners on the car that require that much torque. I have a wrench that will go to 150 ft-lbs that I use for wheel lugs, etc. Can I use simple math to solve my problem? If my son, at 135 lbs stands 20" out on a breaker bar (or a pipe extending the length of the bar) is that sufficiently close for this job? That would theoretically come out to 220 ft-lbs. Additionally, these are the castellated nuts which use a cotter pin, so loosening of the nut is not a concern. I am all for buying tools, but for a once or twice use type of thing I figure I could spend the $70 better elsewhere.
Mike
1986 930
Old 10-04-2004, 08:22 AM
project935's Avatar
Your son-on-the-bar method will be sufficient.
Spend the $70 on go-fast parts or your son for helping out.
Project935
Tube Chassis Turbo RSR/934/935 racer - SOLD in 6/'06
Gruppe B #101
What's next?
Old 10-04-2004, 08:43 AM
Grady Clay's Avatar
Mike,
Put it back together with the nut tight enough to hold and a cotter pin lightly in place. Drive by an automotive shop with the proper (3/4”) torque wrench and 30 mm socket. For a nominal fee (many won’t charge anything) you can have it set correctly.
Remember to bring new cotter pins and the tools to install.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-04-2004, 09:11 AM
Grady, that's an option I guess I never considered. Is the torque value on the axle that critical though? I have no idea.
Mike
1986 930
Old 10-04-2004, 04:10 PM
