skipdup's Avatar
Reading Wire Sizes From Factory Manual
Can anyone tell me what measuring scale Ze Germans used on their workshop manuals? Below is an example... What wire size is 1,0 or 1,5?
1972 911T
1972 911E "RSR"
Old 10-16-2004, 07:12 PM
skipdup's Avatar
Here's the example...
1972 911T
1972 911E "RSR"
Old 10-16-2004, 07:14 PM
autobonrun's Avatar
I assume it's the same as my other maintenance manuals where the number represents the cross sectional area in square millimeters. Why they chose to use a comma rather than a decimal point I don't know.
1,5 would be 1.5 square mm.
0,75 would b 0.75 square mm, etc.
Old 10-16-2004, 07:57 PM
Insane Dutchman
Exactly correct, cross section in square millimetres.....much more sensible than this miserable guage stuff....
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 10-16-2004, 08:05 PM
skipdup's Avatar
Thanks.
So, how do I convert square millimeters to roughly the same gauge equivalent?
I'm obviously not thinking about this right... Must be my public education. L1 & 2 are the left headlight. 1.5 MM seems too small to me.
Thanks,
Skip
1972 911T
1972 911E "RSR"
Old 10-17-2004, 06:32 AM
Irrationally exuberant
ChrisBennet's Avatar
Area equal Pi * radius squared or:
Area = Pi * r^2
So radius = square root of area divided by Pi or
r = sqrt (A / Pi)
Therefore:
"1.5" has a radius of .69mm or a diameter of 1.38mm
"1.0" has a radius of .56mm or a diameter of 1.12mm
"0.75" ...................................diameter of 0.98mm
Maybe someone can convert that to gauge?
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-17-2004, 06:45 AM
Early_S_Man's Avatar
Porsche Crest
The headlamp wires are a bit larger than 16 ga, but smaller than 15 ga ... 1.5 sq. mm vs 1.65 sq. mm ...
Here is an AWG chart:
http://www.tfcbooks.com/referenc/wiresize.htm
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-17-2004, 07:46 AM
skipdup's Avatar
Now I get it. Here's a table that converts from AWG to CSA (Cross Sectional Area - in square millimeters).
Thanks!
Skip
1972 911T
1972 911E "RSR"
Old 10-17-2004, 10:02 AM
For future reference ...
AWG Number CSA (mm sq) Capacity (Amps) per the N.E.C.
8 8.35
9 6.62
10 5.27 30.0
11 4.15
12 3.31 20.0
13 2.63
14 2.08 15.0
15 1.65
16 1.31
17 1.04
18 0.823
19 0.653
20 0.519
21 0.412
22 0.325
23 0.259
24 0.205
Warren Hall, Jr.
Old 10-17-2004, 01:36 PM
Cars would never be able to comply with NEC as to ampacity......as correct as NEC ( National Electric Code) may suggest.
Cars' use will end up with much lighter gauge for the given amp load...a function of cost and weight concerns.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-18-2004, 07:30 AM
