Bird. It's the word...
Help, Have Lost Indicators
Hoping someone has some ideas...
I was installing my TRE "R" tailights and accidently crossed some wires in the harness I made up and blew the fuse. I replaced the fuse but they just wouldn't work. I have now replaced the blinker can behind the dash... still no luck. We're talking both sides and they were working perfectly. Any Ideas out there? Cheers
John Forcier Current: 68L 2.0 Hotrod - build underway |
John,
Hopefully ... the blown fuse incident didn't also take out the stalk switch for the turn signals! My suggestion is to download the SL33-lft.pdf and SL33-Rt.pdf schematics from Sherwood Lee's Rennlist page ... and print them out, then carefully go over your new harnesses to make sure the left and right tail lamp #65 five-pole connectors match the proper color code and function. http://members.rennlist.org/911pcars/WiringDiag.htm
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks Warren. I traced the fault to a poor ground in the dash connection. It appears to have been butchered in the past... I will be re-wiring the section and using SOLDER instead of twisted ends and tape!
Thread Tools | |
Rate This Thread | |
