ignition resistor versus strength of spark
Does an in-line resistor prior to the coil, hurt the strength of the spark as it exits the coil?
I'm trying to put together an ignition set up for a vintage car on a 2 piece points-early distributor.....
I'm not allowed to run a crankfire, and just figured out last night that the pertronix I bought doesn't fit....
what do other vintage (1967S motor) people do?
I have a crane optical in a street car and always wondered if the inline resistor kept me from a stronger spark....
does MSD make a points replacement?
sorry I'm thinking out loud now
brant
Old 10-24-2004, 07:11 AM
Lorenfb's Avatar
If the coil is used in an inductive discharge ignition system versus a CDI, the resistor
will affect the strength (energy) of the spark.
Check out this web site ( www.systemsc.com ) on the Technical page on Ignition Systems
for more info.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 10-24-2004, 07:45 AM
Re: ignition resistor versus strength of spark
so you want to run a simple points and condensor ignition ?
so you're trying to eliminate potential ignition noise ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-24-2004, 07:45 PM
Re: Re: ignition resistor versus strength of spark
Sorry I'm slightly confused by your question.
my ultimate goal is to run the best race (non crankfire) ignition that I can for a track only motor....
I want to get away from points for reliability
If you mean ignition noise like the kind that effects stereo's, then no I don't care
thanks again, I'll check out the web site too
brant
Old 10-25-2004, 07:15 AM
