repair gurus , I need part # help....
I need the part # / description for the channel that runs around the engine bay and holds the large rubber seal in place ,it seems that the morons that fixed the light r/s rear hit decided that it was easier to cut a section out than repair it......
thanks , Sam.
'96 Dodge Viper '09 Maxima '05 zx10..(0-100-0 before your turbo even spools!!) '99 Rottweiler '08 Cane Corso |
Called a rail; try 901.501.796.20 for right (passenger's side), 901.501.795.20 for left (driver's side) and 901.501.797.20 for the rear. Cheers, Jim
One of these pieces?
Or is it part no. 5 in the below figure?
Jim |
Hmmmm ,I'm not seeing it in the pic Bill ,it's about a 1" channel and the seal actually pops into it ,this would be a cross section --> (______) , (rotate 90 degs) and it runs all the way around the inside of the engine bay .
thanks , Sam.
#5....BINGO...(I think) .
Sam.
Look in the second figure (part no. 5) which matches the part numbers I posted. Jim
you guys are gooooooood !!! ,I'll raise a cold one to each and every one of you while I sit in my garage and contemplate turbo flares..........cheers
