yama1's Avatar
Question Is there a benefit in just adding this?
Is it worth changing stock cat to a fabspeed bypass to be used with stock muffler. Would it be better to wait for other changes.
(IE exhaust/exchangers)
I have 160k.
Doing some other maintenance and was thinking of this. All stock currently.
Just curious.
85 Euro 911 carrera
77 911 widebody coupe
"Drive the Ride"
Old 11-04-2004, 06:06 PM
Without improving the induction, you'll be wasting your money by only installing a cat bypass (Fabspeed or otherwise).
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 11-04-2004, 07:03 PM
It may be a waste of money but on mine the exhaust sound got deeper and that made it worth it alone. Actually I took mine off just to get rid of the heat on that side of the engine.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 11-04-2004, 08:40 PM
alf alf is offline
alf's Avatar
Sounds better, weighs less, less heat next to engine, pretty easy to do if your bolts are not rusted in.
I felt an increase in performance when i made this change.
alf
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 11-04-2004, 08:49 PM
Eric Coffey's Avatar
Makes valve adjustments a lot easier too.
Old 11-04-2004, 10:57 PM
Make Bruins Great Again
Por_sha911's Avatar
Clogged cats cause other problems. Sounds cool. Runs cooler (temperature). Opens up the system for other upgrades like chips. Just make sure you won't need the $ if something breaks.
Joe
Old 11-05-2004, 06:46 PM
