| Registered Join Date: Feb 2004 Location: Long Island, N.Y.
				Better tail pipe color
			Hello: A few days I posted pics of my new muffler; a few noticed my tail pipe color looked lean. After a 100 miles it looks better, any comments?? Original pic:   Here's it has @ 100 miles on it:   Regards, J.P. | ||
|  11-06-2004, 08:45 PM |
| Registered Join Date: Mar 1999 Location: Cornwall-on-Hudson, New York, USA
			I'm told by people who know WAY more about this than I do that these days, assessing engine tune and mixture by tailpipe color is a fool's errand.  What you see deposited there has much more to do with where the gas came from, what's in it and a bunch of other factors that have nothing to do with how your engine is running. Stephan
				__________________ Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster | ||
|  11-06-2004, 09:32 PM |
| Administrator Join Date: Feb 2000 Location: Los Angeles
			Have you run any race gas?  It'll burn white, like that.
				__________________ Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 | ||
|  11-06-2004, 10:54 PM |
| Registered Join Date: Jul 2001 Location: Portland Oregon
				 | Quote:
 True pearls of wisdom, if I might say so,.....  Use an A/F meter with a wide-band sensor or a 4-gas analyzer to see for sure.
				__________________ Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com | ||
|  11-07-2004, 01:25 AM |
| Designer King Join Date: Mar 2004 Location: Toronto, ON Canada
			I have to disagree w/ some of you guys.I have always been able to tell how rich or lean my mixture was by looking @ how dark the color was on my CIS car.   I have recently suspected that another poster was running lean w/ some typical startup issues. We richened his mix and the symptoms were alleviated. His tailpipe got blacker, and when he bought a Gunson, he confirmed his richer mixture. I doubt that in the couple of weeks that this occurred, his engine condition changed radically. I have also noticed a change from dark brown to black when I changed my WUR without vacuum to one with, and got the extra enrichment @ WOT. At the time I asked JP if he had a turbo because I have noticed some turbo cars running w/ lighter pipes. And, as Jack said, I have noticed a lighter pipe on some friends' racecars. I think the point is that in any particular area (geographically) there would be a trend in tailpipe color for cars that are set up correctly. Likewise, any change you make in setup would be reflected in color changes. For JP, maybe it would be a good idea to verify your mixture w/ an analyzer to confirm a baseline. I don't know if you have to meet any emission requirements but even if you don't you should be able to compare your starting and running conditions to the pipe color and/or the CO%.
				__________________ Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-07-2004 at 06:24 AM.. | ||
|  11-07-2004, 06:16 AM |
| abit off center |
			How do your plugs look? Craig
				__________________ ______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. | ||
|  11-07-2004, 06:27 AM |
			Paul: The first tail pipe shot was with @30 miles on it(new mufler), since then it's logged another 100(shown in second pic). I had some plug shots, but I think they were inadvertantly erased. J.P. | ||
|  11-07-2004, 11:14 AM |
			In a nutshell, that pipe looks quite normal to me. Where do you live, what engine do you have, and do you have any start or driveability problems? Do you know your CO%?
				__________________ Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone | ||
|  11-07-2004, 12:30 PM |
			Paul: Metro N.Y. 3.2 DME, SSI, E-Hone, SW chip, MB 911 single out muff. CO% unknown at this time. Idle @ 1.3% j.p. Ps. Ethanol additive 10% NYC reg. AKA Crap Gas. | ||
|  11-07-2004, 04:19 PM |
			I don't understand: CO unknown but idle @ 1.3%? I also have a 3.2 but it is an enlarged 3.0 w/o any emission controls. I use Sunoco 94 which can have up tp 10% ethanol. My pipe looks like yours.
				__________________ Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-07-2004 at 06:10 PM.. | ||
|  11-07-2004, 05:42 PM |
			Paul: Last time the tech set the idle, CO it was 1.3%. I need to get an LM 1 AFR tool to know WOT. j.p. | ||
|  11-07-2004, 07:25 PM |
			Gotcha.  Anyway FWIW I think it's fine.
|  11-07-2004, 07:47 PM |
