Better tail pipe color
Hello:
A few days I posted pics of my new muffler; a few noticed my tail pipe color looked lean. After a 100 miles it looks better, any comments?? Original pic: Here's it has @ 100 miles on it: Regards, J.P. |
I'm told by people who know WAY more about this than I do that these days, assessing engine tune and mixture by tailpipe color is a fool's errand. What you see deposited there has much more to do with where the gas came from, what's in it and a bunch of other factors that have nothing to do with how your engine is running.
Stephan
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
Administrator
Have you run any race gas? It'll burn white, like that.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
True pearls of wisdom, if I might say so,..... ![]() Use an A/F meter with a wide-band sensor or a 4-gas analyzer to see for sure.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Designer King
I have to disagree w/ some of you guys.I have always been able to tell how rich or lean my mixture was by looking @ how dark the color was on my CIS car.
I have recently suspected that another poster was running lean w/ some typical startup issues. We richened his mix and the symptoms were alleviated. His tailpipe got blacker, and when he bought a Gunson, he confirmed his richer mixture. I doubt that in the couple of weeks that this occurred, his engine condition changed radically. I have also noticed a change from dark brown to black when I changed my WUR without vacuum to one with, and got the extra enrichment @ WOT. At the time I asked JP if he had a turbo because I have noticed some turbo cars running w/ lighter pipes. And, as Jack said, I have noticed a lighter pipe on some friends' racecars. I think the point is that in any particular area (geographically) there would be a trend in tailpipe color for cars that are set up correctly. Likewise, any change you make in setup would be reflected in color changes. For JP, maybe it would be a good idea to verify your mixture w/ an analyzer to confirm a baseline. I don't know if you have to meet any emission requirements but even if you don't you should be able to compare your starting and running conditions to the pipe color and/or the CO%.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-07-2004 at 07:24 AM.. |
abit off center
How do your plugs look?
Craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Paul:
The first tail pipe shot was with @30 miles on it(new mufler), since then it's logged another 100(shown in second pic). I had some plug shots, but I think they were inadvertantly erased. J.P. |
Designer King
In a nutshell, that pipe looks quite normal to me.
Where do you live, what engine do you have, and do you have any start or driveability problems? Do you know your CO%?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Paul:
Metro N.Y. 3.2 DME, SSI, E-Hone, SW chip, MB 911 single out muff. CO% unknown at this time. Idle @ 1.3% j.p. Ps. Ethanol additive 10% NYC reg. AKA Crap Gas. |
Designer King
I don't understand: CO unknown but idle @ 1.3%?
I also have a 3.2 but it is an enlarged 3.0 w/o any emission controls. I use Sunoco 94 which can have up tp 10% ethanol. My pipe looks like yours.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-07-2004 at 07:10 PM.. |
Paul:
Last time the tech set the idle, CO it was 1.3%. I need to get an LM 1 AFR tool to know WOT. j.p. |
Designer King
Gotcha. Anyway FWIW I think it's fine.
