MBruns for President
JeremyD's Avatar
Correct/Easy way to remove brake pad material.........???
I have a new seat of Porterfield R4S brake pads. I thought I would be fine with 17mm rear pads on my rear c993 calipers and 930 rotors - but the fit is too tight and I need to remove 1-2 mm of material so I don't overheat - You can feel them grabbing from a roll.
So, any good way to remove the material?
I tried driving a few miles - but they just got hot. Any suggestions? Anybody produce a 15mm pad?
Old 11-08-2004, 07:58 PM
JeremyD's Avatar
I know I know - just drive them, right?
Old 11-09-2004, 08:33 AM
Send a message via AIM to Oldporsche
Cool
Belt Sander.
Disc Sander
Good luck,
David Duffield
Old 11-09-2004, 09:24 AM
Bill Verburg's Avatar
Belt Sander
best
Disc Sander
if the belt sander is unavailable.
As i've pointed out many times the pad thickness varies from one manufacturer to another.
Bill Verburg
Old 11-09-2004, 01:28 PM
JeremyD's Avatar
yes you have
Old 11-09-2004, 01:41 PM
