HarryD's Avatar
So Liz, did you get everything squared away?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 11-29-2004, 08:27 PM
Super Moderator
cstreit's Avatar
Harry,
She's picking up the car from my place tomorrow and meeting some of the GruppeB gang.
As everyone suspected this shop, who shall remain nameles for now, really tried to give Liz the shaft. They overcharged for work done, hacked up the permatune trying to get in it, and completely mis-diagnosed the problem. Not only that but they also left some things (like the headlights and turn signals) disconnected. Just posting this as a warning to others: If you are not comfortable with the shop your car is at, get a second opinion! Intuition is a good thing!
1. The ignition module (Permatune) was NOT bad. I bench tested it, checked out fine. Went through the ignition system and found the plug-wires were somewhat dicey. They are being replaced.
2. Some funky and rather suspect wiring was tidied up and/or replaced
3. Brazilian made Bosch coil was weak. A replacement got the car running.
4. The deccel valve was gummed up and disconnected causing bouncing idle off-throttle and stalling. Check/measure/djust the CIS
5. The shop overfilled the oil by 2-3 quarts... Messy!
Fixed several other little things, but the car runs great now and rev's as good as any 2.7L street motor I've seen.
It is reasonably clear to me that they figured Liz as a fish and were ready to take her to the cleaners. Kudo's to her intuition on this one. Needless to say this was NOT a $3500 job.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 11-30-2004, 07:31 AM
Early_S_Man's Avatar
Porsche Crest
That is good news!
Great work, Chris!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-30-2004, 07:49 AM
Still Doin Time
asphaltgambler's Avatar
You go son!!
Old 11-30-2004, 07:54 AM
I would rather be driving
jpnovak's Avatar
Great work! Thanks for helping out. Pelican to the rescue... AGAIN!!!
Old 11-30-2004, 09:43 AM
OCD project capitan
BigD9146gt's Avatar
Good ending to sicking situation!!!!! I was not so lucky with my first 914. Even though the 1.8 L-jet system isn't as expensive as the 911 systems, i was reemed for $2800 parts and labor, and it STILL wasn't fixed. I got fed up and had them put carbs on. The shop... I worked there, the owner was a longtime friend of my dad, and they still charged me $80/hr. Plus when i put in a pointless ignition, they had hooked the coil wires up backwards, frying it instantly. They wouldn't take the part back.
It sounds like they had no clue as to what they were doing, and Liz's wallet was going to be their education.
Don Welch
'73 914ish ->6ish GTish 2.8 twin plug mfi... happy camper.
Old 11-30-2004, 11:58 AM
I have a 1.94MB audio of a young girl being sold headlight fluid. She's also asked if she wants the high performance halagon fluid or regular fluid, + +. If anyone wants it do a Pelican e-mail and I guess put pelican, etc in the subject. It is funny.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-30-2004, 12:47 PM
kqw kqw is offline
So...
Where is this "so called shop" located?????
The Fox
Carrera
Old 11-30-2004, 02:56 PM
HarryD's Avatar
Originally posted by cstreit
Harry,
As everyone suspected this shop, who shall remain nameles for now, really tried to give Liz the shaft. .... snip...
Chris,
Thanks for the update. I'm glad she/you got it figured out.
Harry
2020 MB E350 4Matic
Old 11-30-2004, 04:25 PM
lizmathews's Avatar
Hi All! I was just reading the other post about the parts problems. Very curious. Ronin - I heard that clip too and thought it was quite funny. It makes me cringe when I think about what these jags thought of me! Anyway, Chris to the rescue. He exceeded all expectations. I owe him and all of you back-seat mechanics, a tall cold one!
Old 11-30-2004, 07:20 PM
Brother's Avatar
This might be a stupid piece of 11th hour maintenance guessing but have you tried monkeying with the idle adjustment screw? On my way home from picking up my SC, I cimbed nearly 1500 feet in altitude and coming to a stop would usually shut my car off. Three turns to the left and the car was leaned out enough to run like a champ after that.
The best part is that this won't cost you a thing although the $30 bucks to have your mixture set right is well worth it.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 11-30-2004, 07:36 PM
lizmathews's Avatar
I defer to Chris and the other experts on this one... Didn't you submit a post regarding this a while back?
Old 11-30-2004, 07:57 PM
Brother's Avatar
my bad. I got lazy and was skimming.
I'm glad you got your problems worked out. This is no way to have a first Porsche experience. At least your second Porsche experience was good.
Paul
1972 914 - Sold
Old 12-01-2004, 04:30 AM
Super Moderator
cstreit's Avatar
Two separate problems Brother, but they were interacting.
The low idle/stall was due to the decell valve (the air plate bypass) being disconnected. Not sure why. It had been for a long time and got "dirted up". The weakened coil wasn't putting out enough spark to keep the car running when the idle bounced down to 500RPM or less.
Replaced the coil and plug wires to get it running well. Removed and cleaned up the deccel bypass and it started working as well.
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 12-01-2004, 07:14 AM
Somewhere in the Midwest
MotoSook's Avatar
Somebody monkeying around with the CIS was likely the cause of all of Liz's problems. When the City wrench got it, he went after the wrong thing and screwed the Permatune up (fortunately it was not too screwed up), but the disconnected decel valve should have been a clue.
(Edit: after reading the below comments, I think I should point out that I did not work on Liz's car...the credit goes to Chris).
Old 12-01-2004, 07:31 AM
kqw kqw is offline
So, I take that you spent considerably less than $3,500.00........
The Fox
Carrera
Old 12-01-2004, 07:37 AM
kqw kqw is offline
Great job folks.....
If I lived in Chicago/Area, I would bankroll and tempt you guys to open a shop.
Liz....you are truly lucky to have that experience near you. (as we all have on this board)
Now you are hooked......
Cheers
The Fox
Carrera
Old 12-01-2004, 08:04 AM
kqw kqw is offline
Liz...
You've gotta do a "Drive By" the shop that TRIED to soak you......
Mention that you ALMOST got reemed but you had your Bullsh*&T deflector on.
In reality though.....
As sane folks do, we move on and let it go... But..I know you are pissed....
The Fox
Carrera
Old 12-01-2004, 05:02 PM
