RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
Question on installing shift shaft seals?
I'm ready to install a new shift shaft seal and the output shaft seals (cv flange) .Do I install them dry? Or should I use a lube or a sealant of some type?
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 11-09-2004, 05:26 PM
jeff1hughes's Avatar
i am sure on the shift shaft seal that you should use a light coat of non-hardening rtv sealant (black silicone is good) on the outer edge of the seal when installing it. I would assume that the CV seals are the same.
86 Carrera Targa - Garnet Red Metallic
88 928 S4 - Gran Prix White
Old 11-09-2004, 06:30 PM
AFJuvat's Avatar
light coating of oil on the sealing lip - thats all
AFJuvat
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 11-09-2004, 08:07 PM
Randy Webb's Avatar
I used oil also. Be sure to clean the sealing surface and ensure it is smooth.
Tap the seals in carefully and don't let them get tilted.
Old 11-09-2004, 08:54 PM
just to clarify, when I said outer edge I meant the metal part that contacts the trans housing.
Old 11-10-2004, 05:00 PM
