RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
I need help removing the output flange on tranny
Tonight , I'm going to try to remove the flange (output shaft) that the cv joint connects to on the tranny. I need to replace the oil seals.
What size socket do I need and what tricks can I use to hold the flange from turning while trying to remove the nut? 915 tranny.
Help
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 11-16-2004, 01:37 PM
Grady Clay's Avatar
Rick,
Put two bolts in the flange and use a long bar to restrain the flange. A regular socket will work on the bolt.
Be sure and oil all the surfaces, including seal, when you reinstall the flange. Torque the bolt to spec.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 11-16-2004, 01:47 PM
RickKlem's Avatar
Thanks Grady, Do you remember what size the bolt is?
Old 11-16-2004, 01:49 PM
Grady Clay's Avatar
Rick,
You are taxing my memory – 19 mm wrench size. It must be a socket wernch.
Best,
Grady
Old 11-16-2004, 02:23 PM
