smstcoach's Avatar
Send a message via AIM to smstcoach Send a message via Yahoo to smstcoach
Porsche Crest is this a shifter bushing issue???
Hey folks. This is my first post (pics attached). I purchased my 86 about two weeks ago. It had a PPI and passed without any major issues. Even compression across all cylinders, most everything works, etc... 930 tie rods, chipped, cat bypass (yet to be put on). The car has been running great and I have put about 500 miles on it in the first two weeks. I can't seem to leave it in the garage even though it is not my daily driver. Anyway, I went for a shift into 5th and the shifter swung around about 90 degrees. Now it is all loosey goosey. What is the most likely problem?
Old 11-18-2004, 02:50 PM
MiamiTurbo
She is a beauty, not sure on your issue, but Im sure someone will answer soon!
wanabe911 owner
1974 914 2156cc project
2005 Lotus Elise Original owner
2002 996TT Tip
Old 11-18-2004, 02:54 PM
Send a message via AIM to Oldporsche
Cool
What's that dumpster in pic 1 doing?
Nice looking car.
Will this thing shift from 1-2 or 3-4 and be in the appropriate gears?
David Duffield
Old 11-18-2004, 03:02 PM
smstcoach's Avatar
Did some clean-up in the yard...anyway, shifts fine as long as I have a tight grip on the shifter. It swivels around if I don't.
Old 11-18-2004, 03:04 PM
RallyJon's Avatar
Do you mean the shift knob? Or does the entire shifter actually rotate? The former is easy to solve. Dunno about the latter.
993 · 911 · STI · S4 · rally car
Old 11-18-2004, 03:09 PM
Green Skull 006
Jim Garfield's Avatar
It could be two things. There is an epoxied joint in the shift lever that can let go, or it could be the tapered pin that holds the shift lever to the linkage has worked it's way out.
It sounds to me as though it is the epoxied joint. In my case the pin sarted to work it's way out and the shift lever turned slightly, the epoxied joint works great as long as the shift lever is in it's normal plane, but once it was out of line the joint failed. Both of these issues are easy fixes ( a couple of hours).
I think that I did a posting about the fix, let me see if I can find it.
S Reg 823 R Gruppe 246
1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha"
"It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field.
Old 11-18-2004, 03:17 PM
Porsche Junky
mede8er's Avatar
Hmmm...broken shift pin maybe.... You need to put a short shift kit in anyways....
Old 11-18-2004, 03:18 PM
Fast Eddy's Avatar
You didn't mention if it had a short shift kit or not, some of the older kits you had to glue or epoxy the shifter lever-sounds to me like that came loose (happened to me). You may just need to epoxy the shifter lever in place.
Old 11-18-2004, 03:20 PM
Platinum Member
dad911's Avatar
I think if pull back the shifter boot, you will find the handle is actually two pieces glued together:
You could probably seperate the two pieces, rough up the surfaces with sandpaper, and JB Weld them back together.
Old 11-18-2004, 03:23 PM
Green Skull 006
Found it: Which came first, no 5th gear or spinning shift lever?
Old 11-18-2004, 03:26 PM
19 years and 17k posts...
azasadny's Avatar
Nice car! Congratulations and welcome aboard!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 11-18-2004, 05:23 PM
smstcoach's Avatar
Thank you everyone for the info. I'm amazed at what an incredible resource this forum is. Sounds like Jim found the answer. The description of the shift pin working it's way out and the epoxy giving sounds right. If it ends up being something different, I'll post. Here's another photo (photo's are cool).
Old 11-18-2004, 07:22 PM
smstcoach's Avatar
Just in case anyone checks this thread with the same issue, the shifter is held in place with some sort of epoxy. This problem was solved with a little JB weld on the shifter and was an easy fix that cost me $8.00.
-Jeff
Old 11-25-2004, 08:24 PM
450knotOffice's Avatar
Nice car!! I am partial to black...of course
Welcome to the board.
-Scott
Old 11-25-2004, 08:46 PM
smstcoach's Avatar
Thanks Scott. Glad to see your cab is in the proper color as well.
-Jeff
Old 11-26-2004, 06:24 AM
