PorscheGuy79's Avatar
To split or not to split
I am rebuilding the calipers on my SC, should I split them for the rebuild? It says that this may cause them to leak. Whats my best bet guys?
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 11-23-2004, 05:03 AM
the last thing I would do is split them. I split calipers and had no leak afterwards, only an unknown brake problem of constant air in a line or should I say air being sucked into the line.. whatever.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 11-23-2004, 05:30 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I've never heard of a good reason to split the calipers and wouldn't recommend it. Just pull the pistons, clean them up and thier bores and put it back together with new seals
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 11-23-2004, 06:14 AM
D idn't E arn I t
RANDY P's Avatar
nope, don't split 'em unless they're leaking already- soak 'em in cleaner for awhile instead. In the rebuild kit there's no rings for the thru bolts.
In the movies only bad guys sleep in king size beds.
Old 11-23-2004, 07:35 AM
Senior Member
Superman's Avatar
Nope. Clean, flush, new rubber.
Mocha 1978 911SC. "Coco"
Old 11-23-2004, 07:40 AM
Cool, then i wont. What is a good way to get the pistons out without using compressed air? Im young and dont have a compressor.
Matthew
Old 11-23-2004, 11:20 AM
I seem to remember reading that someone got them out with a bike pump?
It was a few weeks / month or so I was reading the post in the archives......
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 11-23-2004, 11:32 AM
Somewhere in the Midwest
MotoSook's Avatar
Matt, unless you have cocked a piston or there has been corrosion, you should be able to rotate the pistons while pulling them out. Give yourself a little advantage and push the pistons out a little with with the MC while the calipers are on the car. There is a tech article here that is good. Look in the tech article section.
Old 11-23-2004, 11:35 AM
