HELP - field repair - TDC and speed sensors
Can it be done in a parknig lot? With the Porsche tool bag?
Anyone?
I got Shatz & Krum http://www.schatzandkrum.com (Sacramento area mechanic, they are only 1.2 miles away from the car) to "loan me" a TDC and speed sensor. JIm said if they work, I buy them, if not then return them. :thumb:
Shatz and Krum can't even do a diagnosis until next Tuesday.
Hopefully, my friend will be able to loan me his DME tonight, else I gotta' get it towed.
If nothing else, tell me what's involved if I can R&R these with the engine in place.
Thanks.
Nick
'85 Carrera
Old 12-01-2004, 01:54 PM
You should be able to replace/service both sensors without dropping the engine, but I think it would be extremely difficult to do so in a parking lot. I'd tow it to a shop and do the job on a lift...I believe they are located on the left (driver's) side of the engine on the flywheel, close to no. 3 cylinder and pretty high up on the engine. What exactly are your symptoms???
Marc Morrison
1964 356C coupe
'89 911 coupe
2008 Honda Accord
2008 Ford Ranger
Old 12-01-2004, 05:03 PM
kqw kqw is offline
You can't be serious, can you?
As M. Morrison mentioned, what are your symptoms to lead you to the sensors?
The Fox
Carrera
Old 12-01-2004, 05:45 PM
Friend of Warren
Not sure if you can replace them without a partial engine drop or not. Here is a picture that shows their location (circled in green).
Kurt V
Old 12-01-2004, 06:24 PM
I would at least tow it home.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-01-2004, 06:27 PM
Lorenfb's Avatar
"As M. Morrison mentioned, what are your symptoms to lead you to the sensors?"
Right-On!
Some more shotgun troubleshooting -
Luckily a DIYer is doing time & money wasting.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-01-2004, 06:54 PM
Thanks for the replies guys, actually here is my previous thread...
Intermittent NO START, and fail running
Well... I have checked all but the computer and the two sensors, as I don't have a scope.
I have checked:
Full throttle switch - Continuity when open all the way, else open in any other position --GOOD!
Idle switch - continuity when closed, else open --- GOOD!
CHTS 2400 ohms at 60 degree F --- GOOD!
Volume Air Flow Sensor (VAFS) - various ohms --- GOOD!
Intake air temperature inside VAFS --- 2500 ohms at 60 F ---- GOOD!
ISV - hums with ignition in the ON position --- GOOD!
So I have a computer, ignition coil, ignition pickup(ref sensors-then), left... correct?
I am going to check the ignition coil now.
Just before I got it home on the a little rental trailer (yes they do actually fit, but it scraped up my front lip), I found a GAS LEAK! AHHHHHhhhh
And when it barely ran it RAN SOOOOOOO RICH! Black smoke, and I can smell RAW fuel out the exhaust.
This is not the symptoms I had before.
Before, I would be driving and all was well, then either the ignition OR computer would die for 1/2 a second, then suddenly it would run again.
Nick
'85 Carrera
Old 12-01-2004, 08:05 PM
Rich running is often a symptom of a faulty CHT signal. Check the CHT resistance at the DME connector. By the way, you don't have an ignition pick-up, that's what the flywheel sensors do.
Mine did the same really rich run, and my CHT showed good at the connecter. I finally found a broken wire on the harness side of the CHT connector. I fixed it and all was well.
Tim
1986 911 Cab
2008 Audi A6
Old 12-01-2004, 08:18 PM
Thanks Tim.
Tomorrow night I will pursue the values and see if they are the same between what I got at all the sensors and coil, and what the DME "sees".
Nick
'85 Carrera
Old 12-01-2004, 10:55 PM
BAD COMPUTER...
Swapped it with a newly found friend's computer.
Nick
'85 Carrera
Old 12-07-2004, 09:17 PM
