Crotchety Old Bastard
I would think the stock Euro 930 exhaust would be perfect for an SC conversion. There is no cat and very few mods would be needed to make it bolt right up. You may be able to get away with not using an oil pump if the mount is moddified to place the turbo up higher.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
![]() Quote:
![]() looking for a Used BAE kit because i would like to keep from removing the heat exchangers(i dont think they have moved in 20+ years) I DONT want a scavange pump, how much would it have to be modified, anyone have a picture were the turbo sits without modifying it? any way to just add a nice big old spacer to place the turbo up a few inches more?
SWB |
Unconstitutional Patriot
Unregistered
It would be relatively wasy to duplicate the BAE kit, the olny hard to make parts are the rubber boots that go on the throttle housing and air sensor thingy.
If you could get those the rest could be fabricated. My car is running 6 psi right now and I will bump it up soon when i get a CIS issue ironed out. The A/F ratio swings a little, which it did before the turbo also. I've played with the mixture quite a bit, replaced the O2 sendsor, etc. It may be that it is just too far out of normal range, I guess I need to buy an exhaust gas tester to nail it down. The car runs great, but at steady cruise I feel a slight surging as the mixture swings. It's done that since I first got it, for a while I ran with the O2 sensor disconnected because it was bugging me. For all I know it could be a DAPO thing. |
BTW, I replaced the 4 O2 sensors on a friends '97 993 Twin turbo (Protomotive) on Saturday....and all I can say is...Holy $hiT this car is fast.
Warren & Ron, may you rest in Peace. |
Limbo
Sam,
I had a surging / hesitation at cruise with my 79SC and it turned out to be two things. The tip of the rotor was very worn and not providing good spark and one of my spark plug wires was not conducting well. Once I replaced those two things the problem went away, and we had tried everything with the mixture and so on.....
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
Original Owner
Here is how:
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Tsuter is deffinatly a thinker...
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Anyone have website for Knoxville Superchargers. I've searched but have come up with nothing
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
alright so, 930 exhaust sytem with a spacer could put the turbo high enough to gravity drain?
yea, those boots are really what im after ![]()
SWB |
Unregistered
Tsuter, I have the BAE manual and have the lambda system configured exactly as pictured, but don't run with the O2 sensor disconnected. Is that what you mean by open loop? The only difference is the BAE manual calls for the hobbs switch to close at 1.5 psig, mine is set at 3 psig rising.
A couple of years ago I ran without the O2 sensor when it was bad, the only reason I replaced it and hooked it back up because it gives better fuel mileage and better metering under certain conditions and it helped me a pass smog test . Right now I am just about ready to disconnect it and tune it manually like I did back then. I hate to give up and admit I can't make it run as designed, call me a stubborn SOB. Last edited by sammyg2; 12-16-2004 at 07:55 AM.. |
Sammy how do you pass the smog with such a non-stock motor? Have you been sent to a test only station? Do you have to submit to the visual inspection (like in LA and the Bay)?
Mike Searching for a new ride '04 VW GTI 1.8T RIP ![]() '76 911S 3.0 RIP ![]() http://www.pelicanparts.com/gallery/BanjoMike |
Unregistered
My engine is completely stock, it just has a little modification to the intake and exhaust
![]() A year ago November I had to go to a test only station for my biannual smog test, which eventually I passed. Two weeks later I added the turbo. When it comes time to test again I will take it back to stock again, prolly only take a few hours. For those tree huggers out there, the turbo itself does not increase the level of pollution the car puts out, it just affects the visual inspection. Oh, that and also the catalytic convertor that "fell off". ![]() The same smog rules apply to the O.C. as L.A. |
Thread Tools | |
Rate This Thread | |
