TOO RUF's Avatar
Unhappy Battery Box Rust
Well I was doing my brakes this weekend, when I realized that I had a lot of rust. This was from Battery acid. So I Replaced the Front Pan and glued in a new one.
15 Cayman
93 Amethyst 964 Cab & 67 21 window VW Wife's
64 356
69 912 targa
68 911L Hot Rod
Old 01-04-2005, 04:50 PM
abit off center
cgarr's Avatar
Was that the 3M structural adhesive you used?
craig
______________________
Craig
G2Performance
Old 01-04-2005, 05:36 PM
19 years and 17k posts...
azasadny's Avatar
Wow! How did you glue that? I though that would have to be welded. Good looking repair!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 01-04-2005, 06:03 PM
lally911's Avatar
With that much rust around the suspension pickup point you might want to check in the cross member between the suspension points. Hopefully you won't find what I found there...
Keith Lally
85 911 Blue Coupe - gone
84 911 Silver Coupe - gone
Old 01-04-2005, 06:12 PM
TOO RUF's Avatar
I replaced the whole suspension clip in the front. I did weld it in. I finished it off with 3m seam sealer to prevent rust.
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 01-04-2005, 09:51 PM
