Well I was doing my brakes this weekend, when I realized that I had a lot of rust. This was from Battery acid. So I Replaced the Front Pan and glued in a new one.
15 Cayman 93 Amethyst 964 Cab & 67 21 window VW Wife's 64 356 69 912 targa 68 911L Hot Rod |
abit off center
Was that the 3M structural adhesive you used?
craig
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
19 years and 17k posts...
Wow! How did you glue that? I though that would have to be welded. Good looking repair!
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
With that much rust around the suspension pickup point you might want to check in the cross member between the suspension points. Hopefully you won't find what I found there...
Keith Lally 85 911 Blue Coupe - gone 84 911 Silver Coupe - gone |
I replaced the whole suspension clip in the front. I did weld it in. I finished it off with 3m seam sealer to prevent rust.
