Smart quod bastardus
fredmeister's Avatar
ignition timing for 911SC with CIS
Looking for input from memebers on iniital static timing for 1979 911SC with CIS for max performance.
I am currently running about 7-8 degrees before TDC at 900 rpm idle, but wanted to know what the initial timing should be for max performance.
The engine is 8.5 to 1 compression US spec motor. Stock CIS but has 964 cams installed.
I tried getting a reading on my maximum advance at 5500rpm, but am not sure how accurate a reading I can get since it is uncomfortable to be revving the engine to that speed with my head stuck in the engine bay consistently, and trying to take a reading off the crankshaft pulley that is not marked with a scale of numbers.
Thanks for the input.
Old 01-08-2005, 01:29 PM
Formerly bb80sc
Vipergrün's Avatar
On my 80SC, I am running 35 degrees max advance at 6K RPM's, which translates to approx 12 degrees at 950 RPM's. Have you thought about using an adjustable timing light? That way you only have to use the Z1 mark. If you get any detonation, back off the advance a hair.
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 01-08-2005, 03:54 PM
Just got one of those for Xmas as that was my next thought too.
Did you notice a difference in power by running this much advance as opposed to more normal factory settings of around 5 degrees BTDC?
Just wondering if I should expect a noticeable improvement.
Thanks,
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 01-08-2005, 04:05 PM
I bought a 944 headlight assemblies. They seem to fit.and linkage setup is aost exact setup as OEM.
Jagerocks@hotmail.com if you want to see my assemblies and setup.
Cheers
Old 05-07-2021, 09:56 PM
