Besides dropping in a 993 setup what is
the ultimate suspension for an earlier 911 with Carrera flairs? It will be driven on the street and a DE/track car.
With all the changes in bushings/mono balls and what is available now over a couple of years ago what is the ultimate setup today? Let's start with wheels. 8 and 10 x 17's or will something wider fit? 9s and 10s? Bushings? Coil overs or Tbars? Sways? Struts? What is the best we can do with a narrow body car? |
Administrator
10's are all you're going to get under the rear of Carrera flares, pretty much. But it's hard to make an argument for needing much more than that.
Short of the 993 rear end, the best setup would be Turbo trailing arms with the Smart Racing mounting boxes for improved geometry. 935 springplates, too. Wevo just came up with a cool version of these, I think, but ERP has good ones too. If 33mm rear bars aren't stiff enough, then coil-overs make sense. You've got to reinforce and gusset the shock towers and crossmember. What am I forgetting? Adjustable shocks? Limited Slip? Bushings, monoballs and the like? The list always continues to get longer as you go.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
vott does ziss do?
hey Dane, that's easy. just jack up your radiator cap and park a 951...
oh wait, you don't have a radiator cap
951?? Hahhahhhaaaaahahahhaaahhhaah 951? Porsche showing Chevy how to build a Vette. Sadly it still isn't a 911
![]() Thanks for the suggestions Jack. I'll have to ask the resident ""Evil jenius" what majic he'd suggest. |
Don't listen to me because I'm MUCH slower than Jack........but, here's a couple of thoughts.
Trailing Arms: Since the 930 trailing arms are shorter, won't they have more camber change per inch of suspension travel? I thought that maybe 911 trailing arms might be preferable for this reason(less camber change during suspension movement). Springs: Without going coilovers, I'd put in the polybronze bushings. Take the time to fit them perfectly. Monoballs may be kind of rough for the street. How tough are you? ![]() If you are going to go coilovers you probably want to spend some serious time figuring out how to stiffen the chassis. I would think it would be worth it to stiffen more than just the shock towers and crossmember. The body wasn't originally designed to carry the shock loads through those points. The RSRs were modified to include these braces, but I would think bracing further back into the body structure would help more. No structural analysis, just gut feel. Shocks: Custom valved Bilsteins for your specific combination or maybe the JRZ or Fox double adjustables. I'd prefer the adjustments, but they are a lot more expensive. Now why doesn't Bilstein have PSS9s for my 79SC? Other upgrades: I've heard a Ty$on upgrade works really well........
Rob Channell One Way Motorsports 1979 911SC mostly stock ![]() 1972 911T Targa now with a good 2.7 ![]() 1990 Miata (cheap 'n easy) 1993 C1500 Silverado (parts getter) |
vott does ziss do?
as for that TonkaToy thing, know why 951ers don't contemplate such mods?
MBruns for President
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Me like track days
BTW, if you want to price out a local 993 suspension transplant, call
Henry Luft at B&H motorsports. I don't know the cost. BTW, he's done quite a few -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
There is no one-size-fits-all. For a street / DE car things like durability and low-maintenance are important. What is best for the serious racer is not always best for the street / DE car.
I would pass on the coil overs, they won't add any performance but will create a lot of overhead in terms of reinforcing the chassis. These make sense for the serious racer who wants to quickly change spring rates and set ride height trackside. That doesn't sound like you. I'd also pass on the dual/triple adjustable shocks. These are great for the serious racer who knows how to tune them and will do so for each track visited. Again, this doesn't sound like your game plan. Too many things to adjust can be worse than not enough. Spend your time having fun and learning to drive the car faster, and avoid chasing your tail tweaking shocks and springs. Keep life simple, and have fun. I'd advise torsion bars with custom valved bilstein or koni single adjustables. Sizes tbd. Polybronze bearings all around and weathersealed trailing arm monoballs are a given. Quality adjustable sway bars front and rear, there are several nice ones on the market. Out back: factory adjustable spring plates aluminum trailing arms Up front, raised spindles decambered ball joints tie-rod end bumpsteer kit triangulated strut brace Monoballs for strut tops or offset camber plates, depending on tire selection Combine with proper ride height, corner balance and performance alignment, this setup will give you great performance and will be low-maintenance and easy to live with. Choose the tbars properly and match with correct shock valving and you'll have good street ride quality to boot.
Chuck Moreland - elephantracing.com - vonnen.com |
likes to left foot brake.
Agree with all Chuck offered.
Here is a thread with much of the serious and expensive hardware. |
![]() Thanks guys, good stuff. Anything been missed so far? |
vott does ziss do?
![]() yeah Dane. too bad yours wasn't one of 'em
Dumb question which I should know but, are SC trailing arms aluminum?
vott does ziss do?
I wish I knew for sure, (probably wrong on this) but didn't the aluminum trailing arm first appear on the 964?
The SC trailing arms are aluminum.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
vott does ziss do?
DOH! no cookie for me
Something like this would be nice, notice anything different?
Me like track days
W-oww. Rigid chassis. At what point do these projects stop?
Haven't quite figured this out on mine. They don't! This thread helps my setup, Chuck. Sounds like I have only a triangulated brace and the group of your goods -- and I am effectively done. Got the single adjust raised spindle JRZs - rebuilt - at a good price. I'll skip the coil-overs at least for now - Quote from Steve Weiner: "There is no reason a properly setup torsion bar car cannot be as good as a coil over setup"
"There is no reason a properly setup torsion bar car cannot be as good as a coil over setup" I don't think I have a properly setup t-bar car. ![]() If you have raised spindles, does that reduce the need for the bump steer kit? After Craigs ride, not sure I want this set up on my car. How do you determine the correct damper valving? I'd like to put on 29mm T-bars in back and would like to get my dampes valved to match. How do you know?
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
