Make Bruins Great Again
I love the V1 idea. Has anyone done this? Someone tell me what it would take to do it.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Yes - if anyone has put a V1 display unit there, pls post a pic.
I think I prefer using the seatbelt warning cutout -- it's already rectangular (but needs to be enlarged). And there's some irony in using it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Sports Purpose 911 Driver
its good to come back to the board and start a good post!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Time to do the "Weekend Bump"
Has anyone converted a clock to a V1 remote or does anyone know what it would take to do this?
I think I am going for the CHT gauge. Going to contact HS to see if they can make one.
just get block off plate sold for the clock hole and jam the remote unit in it. It'll be ugly, but will work fine and is cheap.
Esthetically, the V1 remote is a rectangle and will look funny embedded in any of the round gauges or holes. I suggest putting them in the seat belt warning light slot.
Ooh, now you're talkin'! Very nice Randy. Who did the work?
David Dryden '86 911 Coupe '05 BMW X5 4.4i |
Yea...were did you get that done. I really want to change out the oil level guage and replace it with a fuel pressure guage in my '69 Type-4 turbo.
-Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
North Hollywood Speedo. They can do almost anything you want.
The small LED turns on when I pull that switch to turn on the auxilliary trans fluid pump. A really cool guage would be one of the early 914 small VDO guages with three windows in it, instead of the usual 911 with two. Here's a turbo tach I had them convert the old electrical boost to a voltmeter, I use a mechanical boost in the clock space; ![]() |
That looks pretty awesome. This is what I have now:
![]() I want to convert the oil tank level to a fuel pressure guage and I want to convert the extra urbo tach that I have to display an air/fuel guage for the turbo. I will give them a call. -Britain
a lot of cool ideas. I am going to get in touch with them I really like the trans temp volt meter!! all of these look cool fellas. Anyone have a good source on those early 914 gauges?
Guest
Posts: n/a
I like the big red oil light myself.
How is that shadow outline "RS" done? Looks great.
Is it just a late model trunk lid emblem in black?
Joe your car is really coming along, nice work!
Guest
Posts: n/a
Randy,
It is a trunk enblem that someone gave me. It looks great in the car. James, I was going to update my project on Pelican tonit but the battery in my camera died. I got it running last night. Wait till you see it. She should be all buttoned up by next month. Getting back to the thread. I like the big oil light. For safety reasons. If you look at my dash where the radio used to be, I have space for 2 or 3, 3" gauges. Maybe ill put something there. |
Thread Tools | |
Rate This Thread | |
