2650# and 430 hp = 6.162
Hell, I am hoping for about 5.5 lbs/hp.
Is it that bump, the periodic oil slick, or the wet surface that is bothering people about PIR?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
So Lyall I gotta ask what is your top entry speed into turn 1?
Fun thread! 175 seems a bit fast for a NA 360+/-hp 3.8 pushing 2650lbs through turn 1 at Pacific Raceways... I think Henry's 650+hp 911 race car approaches that speed. Then again my FIRST HAND experience is limited to only my car. Did anyone get a chance to time some of Ted's clean laps?
BTW I just had Henry adjust my suspension and rotate my tires, and he talked me into a dyno proven exhaust mod that worked good on other NA 3.6 engines in his shop. My previous dual in dual out Magnaflow is now essentially two single in single out mufflers thanks to some awesome fabrication work. Throttle response is noticably superior than before...that's all.
Jason Keep Right Except to Pass! 2000 Audi S4 Quattro Non-Sunroof 1989 BMW M3 (sold 12/06) 1977 911S Wide Body 3.6 Varioram (sold 11/05) |
Friends of Warren
Still I am a little confused by how it reached 175mph...
speed=(rpm * tire Dia)/(336 * gear ratio). Assuming the biggest 18' tire (275/40-18) and stock final and stock 5th gear at redline you would have (6,500 x 26.7)/336 * 2.98) = 173 mph The 5th gear ratio should be .825 (I am assuming max theoretical speed of 180 mph) vs the stock .868 assuming the final drive has remained 3.444. Craig do you have details of the gear ratios? Last edited by 911teo; 04-13-2005 at 08:17 AM.. |
Me like track days
Its an early 90s chassis with that yr G50 FWIW. I know zip about it otherwise.
I also wondered about 175 - it was a Ted and John R. guesstimate based upon needle position vs. steering wheel. Zero time for speed watching at turn 1 at Pacific Raceways! Its is damn scary at anywhere NEAR that speed. Hell, 130 gets my attention is a BIG way....
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Friends of Warren
I hear you about checking the needle... I bet it was more like 160-165mph with stock transmission.
I just run those numbers on my car... I would top out at only 163mph at redline.. That is going to be my next project.... spend some money in optimizing the gear/ratios/final drive relationship. |
Me like track days
I fanned out my ratios - even spacing across the board.
Ended up lowering 3rd and raising 5th - in my 915
Friends of Warren
I have a leg on you.... I am thinking on converting my G50 to 6 gears. On a 964 chassis it is pretty straight forward...
But first I need my car back.... PS I can see the light of the tunnel... car shoudl go to the bodyshop next Monday (we had the wrong LSD from GT transmission) and then we just need corner balancing.... I hope to have it by the 1st of May... ready for the 21-22 DE at CMP |
Me like track days
Gonna be a hell of a car. What tires?
Friends of Warren
BF Goodrich... 275/40-17 and 315/35-17. The poser in me could not resist... Had to go silly wide...
Me like track days
Poser, my butt. That width is excellent.
Can I talk ya into Toyo Ra/1s or Vistoracers - a MUCH better track tire?
Friends of Warren
Dude
my car is a daily driver... I go to work in it. And right now I need to recover from the mega $$$ spent on the whole thing before I get a second set of Lindsay Fuchs. So with the Goodrich I hope I have a nice compromise... We'll see after the 1st event. |
"So Lyall I gotta ask what is your top entry speed into turn 1?"
Dane, I breath the throttle before turn 1 to keep my speed down (tiny bag syndrome). I've seen just over 6300rpm several times as I take a breath and prepare for entry. The 8:39 R&P I have makes my speedo read low but my gear chart puts that at 160mph. Unless I'm chasing or being chased I try to keep my rev's near 6k which is 151mph. PLENTY fast for me..
Lyall 82 930, 2500lbs 430hp Black, Black 85 944 ITS / SP2 racer 87 Carrera, stock, GP White, 03 Boxster S, GP White SOLD 73 De Tomaso Pantera, Grabber Blue 18 Alfa Romeo Giulia - Alfa Rosso Red |
Me like track days
FWIW I run Proxes RA/1s on the street full time now, but then again I'm a filthy track whore (as I am sure you will also become).
The RA/1s are an excellent dual purpose tire when leaning more towards track performance. Jack Olsen etc etc recommended them as have about 12 others who run em. The BFGs are a very good tire with a treadwear rating of 140 or above as per some open track racing rules. Rawk on. You will love your car. ------------------------------------------------------------- I may never even have the nutbags for 151 through turn 1.
Friends of Warren
Toyo Proxes RA/1 are not avaliable in 315/35-17...
My choice was limited to the BFGs, Yoko AVS and Goodyear Eagle F1.... |
Me like track days
For your application the Victoracers are available - fairly equal to the RA/1s
Me like track days
Speaking of tracks.......
Ted (whose car we speak of in this thread), as well as other track friends have said that Spokane Raceway Park in Washington State is the mother of all exciting tracks. One can achieve their vehicle's *top speed* every time on the hugely long straight, then must brake before the kink which leads into an insanely short braking zone before a very sharp turn. I've not been there yet, but will be going with a private group several times this spring and summer. This track is the ultimate Pacific NW test of sphincter shrinkage.
Friends of Warren
But then I need to shave them b4 going to the track etc....
And if I go R compound then I don't have anymore excuses for my poor times... |
