"So the energy stored in the inductor is transfered to C1 until the two diodes in the secondary breakdown. C1 has a lot more to do with the regulation of the ouput than I thought."
Wrong! 1. There's NO regulation. There's just a peak voltage limitation controlled by the zener. 2. C1 is used to reduce secondary breakdown in T1. (Get a power semiconductor data book and read about secondary breakdown and the damage it causes.) The energy not tranferred to C8 is dissipated in the zener and T1. That's why there's a current when NO spark is developed. POWER IS BEING USED!!!!!!!!!!!!!!!!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
As this converter may be called a "pseudo-resonant" flyback converter, C1 has a major role in shaping the pulse on the collector of T1. The peak value of the pulse determines the maximum value of the voltage on the output capacitor C8 (the turn ratio W2/W1 is approximatively 6/1). In steady state conditions (no sparks) everything else being equal, the smaller the value of the capacitance, the higher the peak voltage, the narrower the pulse and consequently the longer the time necessary to fully charge C8. Just to give an example I have observed the variations in the shape of the pulse on the collector of T1 when changing the value of C1 : C1 = 0.5 µF pulse height = 88 V pulse width = 40 µs C1 = 1 µF pulse height = 67 V pulse width = 55 µs (original value) C1 = 2 µF pulse height = 50 V pulse width = 80 µs I have made these test with an input voltage low enough in order to prevent the Zener to enter in action with the lowest value of C1. C8 needs to be charged fast enough to provide good sparks even at the highest rpm of the engine. This is not the case with C1 having a value lower than 1 µF. Quote:
For example, I have measured the input current in the CDI unit I have in hands (under 12 V) , and I found 2.6 A at 6500 rpm and only 1.2 A with no sparks. Quote:
The energy stored on a 1 uF capacitor at 82 volts = 3.4 millijoules
If the voltage on the inductor is 12 volts the inductor should be about 0.36 millihenries. The energy stored in that inductor at 5 amps = 4.5 millijoules. When I = 5 Vc=0 and when Vc=82 I=0. Do you think that the difference is the energy transfered to the C8? I am having trouble visualizing the second picture.
Rick 88 Cab |
The energy transferred to C8 is highly variable between two successive sparks. C8 is charged progressively by successive pulses. The load on the converter is maximum immediately after a spark and asymptotically decreases as C8 is being charged. Please have a look to my answer to Lorenfb about the role of C1. Quote:
"As this converter may be called a "pseudo-resonant" flyback converter, C1 has a major role in shaping the pulse on the collector of T1."
Only from a safety standpoint of T1. "The peak value of the pulse determines the maximum value of the voltage on the output capacitor C8 (the turn ratio W2/W1 is approximatively 6/1)." Nope! The peak voltage on the C8 is detemined by the energy STORED in the transformer primary. That's what a flyback system DOES! "C8 is charged progressively by successive pulses." Wrong! See Ingo and Bob's scope images of the SCR anode. "the narrower the pulse and consequently the longer the time necessary to fully charge C8." Again nope! The charge time is a simple LC (L of the transformer) time constant. "Do you think that the difference is the energy transfered to the C8?" The energy stored in C8 is over 100mj! "With some unavoidable losses it is returned in the battery, as visible in the pictures I provided earlier, thus lowering the current consumption. " Totally incorrect, i.e. if the current is about 1 amp @ 12 volts then power is consumed and NOT returned and so 12 watts is being dissipated: Where? now let's guess; 1. the C1 ?, NO 2. the transformer ?, NO 3. the zener ?, YES (above a certain input voltage) 4. the wires ?, Hardly 5. the power transistor ?, YES TOO MUCH GUESSING!!!!!!!!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 12-18-2007 at 04:01 PM.. |
OK cut me some slack here, is this how it works?
Say C8 is charged to 460 volts
When C8 is discharged C1 won’t have to increase much and a large percentage of the energy stored in the inductor will go into C8. The amount of energy transferred per cycle will go down as the voltage on C8 increases.
Rick 88 Cab |
![]() Quote:
The measurements figures and the pictures I gave in my previous posts cannot be ignored. Quote:
My posts are based on observations and measurements. No guessing here. |
"With T1 still off C1 has to discharge through the primary back into the battery"
Hopeless!!!!!!!
Rick 88 Cab |
I have a few comments along your points.
See the pictures hereunder, all with T1 collector voltage as reference. The first one shows the current across T1 (10 mV/A) : ![]() This one shows the current through ZD1, in the forward direction. The small peak in the zener direction is the beginning of the voltage limitation occurring at the top of the impulse on T1 collector. ![]() The current in W1, as shown in the picture I provided earlier, is the combination of the currents from T1 and ZD1 shown above. The current in C1 shown hereunder is, as could be expected, the derivative of the pulse voltage on T1 collector. ![]() Quote:
I fully agree with your second sentence. |
I can't exactly duplicate the scope photo, but I can come close.
Note that is not a zenner diode, it is the spice default. ![]()
Rick 88 Cab |
May be you would come closer if taking into account my correction about the input voltage I used for the scope picture (10 V) and consequently the estimated value of W1 inductance (0.3 mH instead of 0.36). |
"Just to give an example I have observed the variations in the shape of the pulse on the collector of T1 when changing the value of C1"
So? The charging dv/dt of C8 is UNAFFECTED by C1 whether it's .10uf or 1.0uf. It's not a "shape" issue, i.e. basically no effect on energy transfer! This is NOT a pulsed type of voltage step-up circuit dependent on the pulse shape on the primary of a transformer. It's just an energy transfer circuit - a flyback system JUST like what's found in the inductive discharge ignition system, i.e. energy is stored when the points close and tranferred to the distributor when the points open. It's SIMPLE! "C8 needs to be charged fast enough to provide good sparks even at the highest rpm of the engine. This is not the case with C1 having a value lower than 1 µF." Not really! The C8 charge time is JUST a function of: C8, Ipeak(primary), L(secondary), L(ignition coil) and Vzener (determines the max voltage). "The unused energy of W1 is sent back to the battery and this occurs for a time longer than the blocking period of T1." Another incorrect statement! If that were the case, the average input current would be zero, i.e. no power dissipation when there's no spark output, which is NOT the case as the average is greater than 1 amp. Power (energy loss over time) occurs from the forward bias of the zener (during the T1 off) and the losses of T1 as it's switched off. Thus, energy is NOT conserved as implied in a number of posts when no sparks occur. Furthermore, C1 has little affect when charging C8 as C8 is reflected to the primary as the square of the turns ratio times C8 to the primary. Without C1, the circuit energy from the primary current ramp STILL transfers fully to C8. C1 can be reduced to a .10uf which allows the zener to limit the peak voltage at a much lower input voltage. Thus, the C8 charges to a voltage determined by the the turns ratio times the V(zener) even with Vin = 10 volts. So, the claim that C1 is critical for the so-called resonant charging has no validity. As defined previously, the circuit is JUST a basic flyback circuit where C1 limits the inductive energy seen by T1 when switching off. The above should be obvious when using the proper simulation values and elements. Better yet, just replace C1 with a .10uf and see the effect. It's very simple! Actually, the circuit works very well using .10uf, i.e. notwithstanding the potential for secondary breakdown in T1, and better at low input voltages which occur at cold temp cranking.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 12-19-2007 at 08:11 PM.. |
Hey I learned something today
Note the timing in the simulation is determined by the time it takes the primary to reach the peak current determined by the base current and the transistors beta. If anyone wants to play with LTSpice PM me your e-mail and I'll send you the .asc file (schematic). ![]() ![]()
Rick 88 Cab |
).Do you think the figures I gave on the variations of duration and height of the pulse on T1 collector in relation with changes in the value of C1 are invented ? Quote:
I am talking about the consequences of modifying the value of C1 in the converter of a 6-pin CDI, and accessorily to show that the value of 1 µF chosen by the Bosch engineers was likely the best one once the other compelling parameters are fixed. You seem to talk about the general principle of flyback converters, in which I agree that they can be built with any value of capacitor at this place. Quote:
This duration depends on the duration of the pulse. You should not introduce Vzener in this discussion. Its action is not fundamental here and just prevents overvoltage to occur with the highest possible values of the battery input voltage. Quote:
There is of course various sources of losses in any design. I have just shown that some energy is sent back toward the battery during a part of each converter cycle when in idle conditions, so that the consumption of a CDI unit is significantly lower in idle condition than at maximum rpm. This is a FACT you cannot ignore. Quote:
Just for fun I have put a 0.1 µF capacitor instead of the original 1 µF for C1. I have found for the consumption (at 12 V) the following figures : 0 rpm : 2.4 A 600 rpm : 2.4 A 6000 rpm : 2.4 A With the original value of 1 µF the consumption is : 0 rpm : 1.2 A 600 rpm : 1.5 A 6000 rpm : 2.4 A I just wonder how much time will live ZD1 with a 0.1 µF C1
"If anyone wants to play with LTSpice PM me your e-mail and I'll send you the .asc file (schematic)."
Total waste of time! Just buy: 1. a Bosch CDI 2. a scope 3. a basic electronics book
.Quote:
But its presence is necessitated to attenuate the consequences of an input voltage varying between 10 to 15 V by large. Quote:
![]() I could be wrong in item #5 above but it seems logical. It seems like if the core saturated you would see some other effects also, current, voltage spikes etc. When the thing is fully charged and the energy is going from the battery to the inductor to the capacitor and back to the battery is the shape of the voltage on the collector = Vout * Sin(sqrt(1/(L* C1))) for a half cycle?
Rick 88 Cab |
Here is a confusing example at partial charge
Rick 88 Cab |
"the energy that is stored in the capacitor, 1/6th the output voltage is returned to the battery.
peak capacitor voltage high = most all of the energy initially stored in inductor is returned to the source" "T1 turns on and dumps remaining C1 charge" "Hum??? What could this be, may be an energy loss? But I just said: "most all of the energy initially stored in inductor is returned to the source". Let's get the electronics book back out!" Still doesn't understand the basics of the circuit. So when trying to do a simulation: GARBAGE IN = GARBAGE OUT
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone Last edited by Lorenfb; 12-20-2007 at 01:31 PM.. |
