LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Originally Posted by Lorenfb View Post
"the energy that is stored in the capacitor, 1/6th the output voltage is returned to the battery.
peak capacitor voltage high = most all of the energy initially stored in inductor is returned to the source"
Still doesn't understand the basics of the circuit. So when trying to do a simulation:
GARBAGE IN = GARBAGE OUT
I don't understand.
It seems like you are saying that when the C8 is fully charged nothing is returned to the battery.
This is clearly incorrect. The first scope photo shows that. You can't argue that just by saying it dosen't work that way. "Who you gonna believe, me or your lying eyes".
Rick
88 Cab
Old 12-20-2007, 02:35 PM
Originally Posted by rick-l View Post
This is what I was tryng to say. I was thinking of it in terms of energy
  1. It appears that the inductor charges until it reaches 5 amps.
  2. This stores a finite fixed amount of energy in the inductor
  3. The voltage on the capacitor (peak) when the transistor is off is 1/6 the output voltage.
  4. nothing is transfered to the output until the capacitor is 1/6 th the output voltage
  5. the energy to charge C1 up to 1/6th the output voltage comes from the energy stored in the core
  6. the energy that is stored in the capacitor, 1/6th the output voltage is returned to the battery.
    • peak capacitor voltage low = most all of the energy stored in inductor is transfered to the output
    • peak capacitor voltage high = most all of the energy initially stored in inductor is returned to the source
By large, I would agree to your description. On the point 6, I would rather say : the energy remaining in the couple C1/L(W1) is returned to the battery.
You can kind of see this is the sim below when the capacitor voltage goes up current in the inductor goes more and more negative. Also in the previous V out plot the output takes bigger steps when the peak voltage on C1 is low.
Nice simulation. The overall shape is close to what may be seen on a scope.
I could be wrong in item #5 above but it seems logical.
It seems like if the core saturated you would see some other effects also, current, voltage spikes etc.
In fact there are such spikes on my pictures !
When the thing is fully charged and the energy is going from the battery to the inductor to the capacitor and back to the battery is the shape of the voltage on the collector = Vout * Sin(sqrt(1/(L* C1))) for a half cycle?
I confess that I do not know. If T1 would remain open, it would be an attenuated sinusoidal signal. So is it a half sinusoid ? is this important ?
Old 12-20-2007, 03:21 PM
Here is a confusing example at partial charge
  • I(L1) (BLACK) ramps up to 4.5 and transistor shuts off
  • I(C1) (BLUE) charges C1 to 35 volts
    • I(L1) goes down as C1 charges - less energy
  • Now that V(col) = V(out)/6 + 2 * 6*Vd (should be but isn't exact) the output diodes conduct
    • I(L2) goes positive
    • V(out) rises
  • When v(out) = 6 * V(col) etc I(L2) = 0
  • C1 starts to return energy to source
  • T1 turns on and dumps remaining C1 charge
There is something that does not correspond to reality with I(L1) (black) :
The current cannot decrease instantly to zero when T1 shuts off.
Old 12-20-2007, 03:30 PM
At this voltage level and with C1 charged to Vout / 6 it operates like the flyback Loren is talking about. The flux in the core forces I(L2) positive (I(L2) = 1/n * I(L1) where n = turns ratio) so the flux does not change instantaneously.
Rick
88 Cab
Old 12-20-2007, 04:07 PM
Lorenfb's Avatar
It's simple:
Energy In ~= Energy Consumed
Watt-second = joule
Power In = 1.0 amps X 10 volts = 10 watts
Osc. Freq = 3.3 KHZ
Energy In = 10 watts X 300us = 3.0mj
Energy stored in 1uf capacitor when T1 switches off = 80V X 80V X 1uf / 2 = 3.2mj
Therefore all the energy intially stored in the osc. system is consumed and basically
none is returned. The energy is consumed by the forward biased zener (during the
dumping of the L current - after C discharges) and T1.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-21-2007, 09:40 AM
It's simple:
Energy In = Energy Consumer
No one is saying it doesn't consume energy.
C8 charges to 460 volts to provide energy for the spark
There are also switching losses, core losses, leakage yada yada yada...
What is being discussed is how when C8 is charged energy is returned to the battery.
The mechanism is exactly like how the flyback in a horizontal deflection coil in a CRT works. Ramp up the current, turn off the Horizontal Output Transistor which dumps the energy into a capacitor and the L-C reverses the current and rapidly returns the beam
If energy is not returned to the battery when C8 us fully charged how do you explain this?
Just for fun I have put a 0.1 µF capacitor instead of the original 1 µF for C1.
I have found for the consumption (at 12 V) the following figures :
0 rpm : 2.4 A
600 rpm : 2.4 A
6000 rpm : 2.4 A
With the original value of 1 µF the consumption is :
0 rpm : 1.2 A
600 rpm : 1.5 A
6000 rpm : 2.4 A
It's simple:
dumping of the L current) and T1.
Are you talking about the zener diode being in reverse breakdown or forward bias? For a normal input voltage range I don't think the zener ever breaks down. I don't have one to experiment with but I am pretty sure you could replace the zener with a 1n4003 and with a 12 volt input the output would still be ~460 volts
Just to give an example I have observed the variations in the shape of the pulse on the collector of T1 when changing the value of C1 :
C1 = 0.5 µF pulse height = 88 V pulse width = 40 µs
C1 = 1 µF pulse height = 67 V pulse width = 55 µs (original value)
C1 = 2 µF pulse height = 50 V pulse width = 80 µs
I have made these test with an input voltage low enough in order to prevent the Zener to enter in action with the lowest value of C1.
You do agree that these voltages on the primary during flyback would limit the output correct?
Rick
88 Cab
Old 12-21-2007, 08:04 PM
Lorenfb's Avatar
"What is being discussed is how when C8 is charged energy is returned to the battery."
It's not. The proof indicates such!
"Are you talking about the zener diode being in reverse breakdown or forward bias?"
It's forward biased. The LC oscillation ends because of the zener across the capacitor,
i.e. the zener acts as a diode (forward bias) and clamps the capacitor from charging
in the reverse direction when the inductive current is negative. The base emitter
diode and the collector base junction of T1 can act as a diode without the zener.
"I don't have one to experiment with but I am pretty sure you could replace the zener with a 1n4003 and with a 12 volt input the output would still be ~460 volts"
Correct!
"You do agree that these voltages on the primary during flyback would limit the output correct?"
No! As I said before, a .10uf still produces the same peak output. If the simulation
worked properly, it should indicate that too.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-21-2007, 08:54 PM
Proof ? Which proof ? The figures and scope pictures that I provided about the power consumption of a 6-pin CDI unit clearly show such a return.
Correct!
I agree too. I presume that was the choice originally made by the designer to limit the Zener diode reverse conduction to the highest input voltage range (above 12 V for example).
A 0.1 µF C1 produces the same peak output as a 1 µF C1 ONLY because of the presence of the Zener diode.
If the Zener diode was replaced by a simple diode as in the Rick-I's simulation the output voltage would be much higher with a 0.1 µF C1, as I have shown in a previous post for some other values for C1.
With a 0.1 µF most of the energy in excess at low rpm is dissipated in the Zener diode rather than being returned to the battery as it is with a 1 µF C1.
This is clearly visible with the power consumption figures I have provided earlier.
With C1 = 0.1 µF the power consumption of the 6-pin CDI unit becomes :
0 rpm : 2.4 A
600 rpm : 2.4 A
6000 rpm : 2.4 A
0 rpm : 1.2 A
600 rpm : 1.5 A
6000 rpm : 2.4 A
Old 12-23-2007, 03:29 AM
Lorenfb's Avatar
"Proof ? Which proof ?"
Are you brain dead?
Watt-second = joule
Power In (consumed) = 1.0 amps X 10 volts = 10 watts
Osc. Freq = 3.3 KHZ
Energy stored (and then consumed) in 1uf capacitor when T1 switches off = 80V X 80V X 1uf / 2 = 3.2mj
WHERE'S THE ENERGY RETURNED??????????
AND maybe you just can't properly understand what the scope traces actually MEAN!
What a waste of time.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-23-2007, 09:10 AM
i.e. the zener acts as a diode (forward bias) and clamps the capacitor from charging in the reverse direction when the inductive current is negative.
If the current in the primary is negative isn't it going back into the battery?
Rick
88 Cab
Old 12-23-2007, 09:48 AM
Are you brain dead?
Watt-second = joule
Osc. Freq = 3.3 KHZ
The above text that you are repeating again and again has nothing to do with a "proof".
A real "proof" would have been to demonstrate that my pictures and figures were invented. I recognize that it is always difficult to contradict facts, but to treat me of "brain dead" does not seem to be a valid alternative.
Sorry. I had exactly the same feeling about you, if you are talking about my scope pictures.
For this very last point I agree with you.
Old 12-23-2007, 10:55 AM
Lorenfb's Avatar
"A real "proof" would have been to demonstrate that my pictures and figures were invented."
Not invented, just doesn't understand what's really happening.
"If the current in the primary is negative isn't it going back into the battery?"
Correct! But that doesn't mean the energy is saved. The coil's current just
flows thru the power supply (remember power supply is basically a voltage
source with zero ohms) as it charges the capacitor and as the capacitor
re-charges the coil (field builds up in the coil). The coil trys to re-charge
the capacitor but the coil current by-passes the capacitor because of the
forward bias diode which results in a loss of energy.
Furthermore:
Energy stored in the coil = 4.6 amps X 4.6 amps X .30 mh X .5 ~= 3.2 mj
Iavg = 1.0 amp = Ipeak X .5 X Duty Cycle = 4.6 X .5 X D.C.
Duty Cycle ~ = 45%
Bottom line: All the calculations basically indicate the same; Little to no energy returned!
There's NO mis-interpretation or one's VIEW (scope traces) when it comes to equations.
The numbers don't LIE.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 12-23-2007, 11:03 AM
I have encountered a bunch of these 1980's vintage self resonant power supplies.
  • In my broken (now fixed) Phillips oscilloscope
  • modifying Compact Fluorescent Lights
  • the electronic flash in disposable cameras
An Internet search doesn't yield much useful information about how these work.
jmchrist
I have learned alot from your scope photos and help with analysis
Rick
88 Cab
Old 12-23-2007, 11:22 AM
Bosch 6 Pin CDI
Where can I get a C8 1.4uF 600v capacitor for my 6 pin CDI? Is this just a standard capacitor??
Tim
Tim
1986 930
Gone:71,2,4 914's, 70T, 71T(RS),77S
Old 04-01-2008, 10:35 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I have used a this one successfully a couple of times in the past: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=EF6155-ND. I have not been able to locate the original style capacitor. Let me know if you find something other that matches closer.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 04-01-2008, 10:59 AM
Cdi
Thankyou. I will if I find a better source.
Tim
1986 930
Old 04-01-2008, 11:15 AM
Hi gents,
After testing I found that C8 was open circuit in my CDI. I replaced it (and also fitted a bigger SCR) and now it all works again. I wanted to leave it running on the bench a while before re-firtting it to the car. What input frequency should I use to simulate 8000RPM? I figure if it works OK like this then it will be fine when on the car (clearly I don't rev mine to 8k)
I reckon it is approx. 400Hz
Can anybody confirm this or tell me what it is?
Thanks for helping...
Old 04-19-2008, 08:11 AM
8000 rev/min * 3 sparks/rev = 24,000 sparks/ min divided by 60 = 400 sparks/second or 400 Hz
Rick
88 Cab
Old 04-19-2008, 08:28 AM
Thanks Rick
Regards
Old 04-19-2008, 09:19 AM
Originally Posted by SteveCarr View Post
Hi gents,
My C8 was bad also. I wonder if this is common.
What is the "SCR"? Sorry, I know zero about electronics.
Tim
1986 930
Old 04-19-2008, 09:33 AM
