Early_S_Man's Avatar
Porsche Crest 6-pin SC/Turbo CDI unit repair documentation
Well, after a bit of a delay ...
Here's the schematic and replacement parts list for the Bosch 0.227.300.004 6-pin CDI unit, cussed & discussed at great length ... and used on SCs & Turbos thru '89!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-24-2005, 06:15 PM
Great work Warren. This is what makes this board as great as it is.
Tim
1986 911 Cab
2008 Audi A6
Old 01-24-2005, 06:20 PM
Somewhere in the Midwest
MotoSook's Avatar
Excellent, Warren!
Old 01-24-2005, 06:27 PM
Irrationally exuberant
ChrisBennet's Avatar
Awesome!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 01-24-2005, 06:42 PM
randywebb's Avatar
Now somebody post a circuit board pic
- That's defintiely $400 worth of parts isn't it.....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-24-2005, 09:21 PM
Grady Clay's Avatar
Warren,
Thanks!
Here is the thread on the Bosch 3-pin. It has a wiring diagram also.
Perma-tune CD or Bosch CD?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 01-25-2005, 06:41 AM
Senior Member
Superman's Avatar
Very cool. I just wish I understood.
Which of those parts fails, typically, when a Bosch CDI unit stops working?
Mocha 1978 911SC. "Coco"
Old 01-25-2005, 07:12 AM
I would rather be driving
jpnovak's Avatar
Very Nice Warren!
Superman, I think the Thy might have the best chance of going bad. of course, there is always the chance of a blow cap, diode or resistor.
Old 01-25-2005, 07:45 AM
pwd72s's Avatar
Too true, Supe...we mere mortals wouldn't understand. But in the right hands, this info is valuable. I try to have the info on hand for those with the right hands.
Old 01-25-2005, 10:02 AM
randywebb's Avatar
Component replacement and checking is not that hard on these older analog items. You could take a course at a community college and I'd bet 1 course would do it. This also helps stave off Alzheimer's if you are turning gray... If you screw it up, then send it in for re-grooving by a pro.
Old 01-25-2005, 10:53 AM
Great work Warren...
Another question - what about the pin-out for the 6 pin connector? Is there any place I can find that?
thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 01-25-2005, 01:06 PM
Porsche Crest
Here is the pinout looking into the connector with the mounting flange sitting on the hand or table ...
. 31/1 ... TD ... 31d
. A . . . . 15 . . . 7
31/1 -- Power ground
31d -- Signal ground [green coax shield] for trigger signal
15 -- +14 Volt power lead
7 -- Trigger signal from distributor magnetic pickup coil
TD -- Tachometer Drive signal
A -- +460 Volt pulse output to coil
Warren Hall, Jr.
Old 01-25-2005, 08:44 PM
Here are some resources worth reading if you are a bit rusty on the theory of operation ...
http://www.irf.com/product-info/thyristor/manual/scr_manual.pdf
http://www.st.com/stonline/books/pdf/docs/4347.pdf
http://www.st.com/stonline/books/pdf/docs/5201.pdf
Warren Hall, Jr.
Old 02-05-2005, 08:26 AM
Porsche Crest
And, here is an application note from RCA that may be helpful ... after much difficulty with pic uploads [never copied the image code to edit window -- multiple attempts] ...
Warren Hall, Jr.
Old 02-05-2005, 08:52 AM
Porsche Crest
And, here are the last two pages of AN-6288 ...
Warren Hall, Jr.
Old 02-05-2005, 09:28 AM
Crusty Conservative
silverc4s's Avatar
I nominate this entire thread to become a PP Tech Article. Invaluable information from Warren as always, Thanks!!!
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 02-05-2005, 09:57 AM
Porsche Crest
Here is a bit of design info from GE Semiconductors Electronic Data Library #400.6 on the single-transistor inverter as used by Bosch in our CDI units:
Warren Hall, Jr.
Old 02-21-2005, 01:19 AM
KobaltBlau's Avatar
Truly awesome. Adding to the knowledge bank, Warren!
Andy
Old 02-21-2005, 10:15 AM
Grady Clay's Avatar
Randy,
Thyristor is an early name for a Silicon Controlled Rectifier (SCR). The name is a combination of Tryratron tube and transistor. The beauty of an SCR is that a miniscule current or pulse can turn on a huge current and it stays on until the source current drops below a certain threshold. This is used in CDI and household dimmers.
Best,
Grady
Old 02-21-2005, 11:27 AM
randywebb's Avatar
You're right -- I was thinking of thermistor.... Dunno whether to blame it on age or elapsed time since I've done any electronics work... I'll kill that post.
Old 02-21-2005, 11:59 AM
