Aussie's Avatar
SC Question light washers
Does anyone know if the early 911sc's all had headlight washers as standard equipment?
Mine has the washers, but they are not hooked up, and there is no washer switch inside the cabin.
I doubt porsche would have the jets on the bumper bar, if you didn't order headlight washers.
Wondering if it is the original bumper bar thats all.
1969 911 T (SOLD), 1977 911SC (SOLD), 1999 BMW M3 (SOLD), Current Car 2005 Lotus Exige
Old 01-27-2005, 11:39 PM
Now in 993 land ...
aigel's Avatar
No washers here. Definitely not a standard item in the US.
George
81 SC (sold)
Old 01-27-2005, 11:43 PM
ruf-porsche's Avatar
The headlight washers only work if the headlights are on and the switch to turn on the washer is the same switch use for the windshield.
Old 01-28-2005, 03:36 AM
Recreational Mechanic
Nickshu's Avatar
I would guess someone may have replaced the bumper and installed one with washers. The switch is on the instrument panel, to the right of the speedo or tach, I don't recall which.
The headlight washer pump is located in an indentation in the reservior in front of the left front wheel. You should be able to see it if you crawl under there. It's a large silver cylinder. Looking for this might help you determine if someone actually converted your car (less the dash switch), or just installed a bumper with nozzles.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 01-28-2005, 04:04 AM
Noel's Avatar
Definately an option.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 01-29-2005, 05:35 AM
frankc's Avatar
For the 74-83 cars with headlight washers, the washers were controlled by a separate high-pressure pump which was located in the trunk area near the battery. There is also a separate swith to operate them.
The washer pump was moved to be integrated with the washer fluid tank in the left front fender well starting in 84 (Carreras). The tank was redesigned to accomodate the new recessed fog lights.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 01-29-2005, 09:03 AM
