randywebb's Avatar
I'd have gotten a used bracket mount...
Did you check first to be sure you got the right part for your year, etc.?
Anyway - $48 isn't that much in the long run.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-31-2005, 04:14 PM
biosurfer1's Avatar
well i FINALLY was able to get the rod and coupler lined up and was able to go through the gears. i took it around the block and the sfhit rod bushing if definatly not tight enough, it hums around the rod, so i odered another one of those and cancelled the bracket, i think i can make the old one work, it was a little bent, but looks fine now. on the semi bright side, it does seem to shift a little better, hopefully a lot once the rod bushing is on, if anyone wants to do this, i have a huge list of what not to do. thanks for all the help, especially todd and randy, i'll let everyone know how it goes, fingers crossed!!
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 01-31-2005, 05:07 PM
