doozer's Avatar
Talking Wheel spacers effect on handling
Does spacing out the front wheels (using spacers) have a negative effect on handling??
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 02-02-2005, 12:14 PM
Chuck Moreland's Avatar
Front spacers reduce the wheel rate by effectively lengthening the control arm.
They increase the scrub radius, making steering effort a bit heavier.
They widen the track.
They change the ackerman angle.
These are not necessarily negatives.
Chuck Moreland - elephantracing.com - vonnen.com
Old 02-02-2005, 12:25 PM
doozer's Avatar
As always, Thanks Chuck!
Todd
Old 02-02-2005, 12:27 PM
Also, by lenghtening the control arm effect you increase the negative camber generating more inside wear on your front tires. I would say that handling gets better.
Old 02-02-2005, 12:49 PM
Actually spacers do not effect camber because they are on the outboard side of the strut. acheiving increased camber requires lengthening the control arm inboard of the strut.
Old 02-02-2005, 01:01 PM
doozer's Avatar
Correct, no change in camber at the centerline, but the travel of the leading edge of the wheel/tire will be greater.
Todd
Old 02-02-2005, 01:19 PM
Moving the front wheels out adds stress to the outer wheel bearings which are smaller and weaker compared to larger inner bearings which could cause them to fail prematurely.
Cheers,
Joe
Old 02-02-2005, 02:28 PM
