doozer's Avatar
Talking Machine work on my 930 4 speed transaxle
I just got some photos of work in progress on my 930 box..
Todd
I drank what? = Party out of bounds - PriceLESS - BudWIZER
"Boy Im gonna burn you a new one! - A new what officer?" = night in jail
993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Old 02-02-2005, 12:45 PM
beepbeep's Avatar
What is being done?
Thank you for your time,
Old 02-02-2005, 01:35 PM
David's Avatar
I'll second beep's question, what are you getting done?
Since my engine project is nearing completion, I need to decide on my 930 box. It shifts well, but I'm planning to put a 8:39 R&P in. Since I've been so slow with everything else, I'm thinking about sending it out to have it done. Who's doing your's?
Old 02-02-2005, 04:46 PM
doozer's Avatar
Patrick Motorsports is doing it for me with a late 930 box:
Complete rebuild and blueprint for high torque/hp
Machining for oil squirters aimed at top of gears and ring & pinion
Guard GT Torque Biasing Diff
Billet side cover
etc...
Todd
Old 02-03-2005, 07:43 AM
Cory M's Avatar
It looks like they put in sleeves for the bearings. The holes that the bearings press into tend to wear out, allowing the race to spin in the hole and potentially affecting the shaft alignment. Wevo does a similar repair but I believe they use an hourglass shaped steel piece that holds both bearings.
Old 02-03-2005, 08:03 AM
doozer's Avatar
I think the WEVO unit is more for restoring a box that is way out of spec..
Todd
Old 02-03-2005, 08:25 AM
beepbeep's Avatar
Hmm...not that I've heard of warped 930 housings but it sounds re-assuring.
Old 02-03-2005, 08:48 AM
Irrationally exuberant
ChrisBennet's Avatar
Billet side cover
etc...
So you decided to go with the billet side cover in the end? Did Patrick mention the reason (besides selling a $500 part) that this was necessary?
Scroll down in this post Is this a smart upgrade during a transmission rebuild? for Weviod's comments:
Originally posted by Weviod
"We prepare the cases of a 930 transmission for a customer who has over 600 ft/lbs of torque and he uses the stock 930 side cover. His failures (which are not insignificant) never seem to be related to the stiffness of the side cover.
I would not choose to use a billet side cover based on stiffness."
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-03-2005, 09:30 AM
beepbeep's Avatar
Yeah, that was what I tought as well. Forces on 930 side-plate are highest in 1:st gear. 930 1:st gear is very high, so it shouldn't stress it enough...and even if you happend to have mother-of-all-engines turning the wheels this force will be limited by tire-traction.
I know a guy doing lot's of drag-racing on his G50-equipped 3.6TT-powered 930 (engine is almost into 1000Nm range) and he never ever damaged side-plate. He broke heaps of halfshafts, yes....but no side cover.
I seriously doubt that you can generate enough launch force to damage OEM 930 plate, BB V8 or not. Especially not with it's stock high gearing. 935:s didn't have any bling-bling side covers either.
Old 02-03-2005, 09:40 AM
doozer's Avatar
Ok, so I did not need the side cover - we will call it transmission jewelry...
Todd
Old 02-03-2005, 10:10 AM
