ive got some bad rust right under my reer widsheild and im havin trouble on how to deel wit it. if u have any info on it pls tell me cuz i dont want to make this peice.
Spell check?
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
MBruns for President
Yikes -
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
i know, was just in a hurry
Air Medal or two
I assume you have the window out?? then take a wire wheel and clean the puss out......if there is metal left,, POR it....if no metal weld in a pc..Maybe mom here sells the corners?? I know they sell the fronts
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
i see
Norm
I think AWOL is just having some fun with all of us as well as asking a serious question...imho Cheers Brian
Mens Agitat Molem 1970 T (presently in pieces) |
Weather permitting I will be doing some of the semi-final cutting up of a 68 coupe this weekend, glass comes out and roof is coming off, let me know if you need replacement pieces such as where or send me a pic of yours so I'll know how much extra to leave. Cutting some special orders for some others off this same car.
Stressed Member
AWOL-
I have the same problem. I was able to buy a replacement panel from EASY in CA from a donor car. New panels are not available. It's a lot of work drilling out all of the spot welds in order to remove the old panel and install the replacement, but it's the right way to do it. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
thanks and ill post some pics later
Pretty common rust area. If it's surface only, clean it up and POR it.
If more substantial 1) cut ![]() 2) weld ![]() 3) grind ![]() This corner require almost zero fill.
Chuck Moreland - elephantracing.com - vonnen.com |
thanks ill use thoes pics
AWOL,
Just a side note, you may want to edit your location in the "user CP"; and just list a city instead of your actual address. Post pics of the project as it progresses.
Donnie Currently Porsche-less..... ![]() |
Thread Tools | |
Rate This Thread | |
