Warped rotors causing pull to right?
I just installed new shocks all around on my 69S and set the ride height as well. Before I did this, the car had a distinct pull to the right and that pull is still there. Nothing seems to get rid of it. I have been working with the 911 alignment handbook posted on this BBS and one of the suggestions in that pamphlett is that a warped rotor can cause the car to pull even when not braking. So I checked the front rotors and even without the brakes applied there is a definite spot on the right rotor where it rubs the pads. I can see a very slight warping, but really nothing significant. Is this enough to cause the car to pull? Any other suggestions? The car is scheduled to be aligned and corner balance in a few weeks, but I would like to get it set up as good as I can before then.
Thanks.
Bill
Old 02-03-2005, 10:28 AM
Jamie79SC's Avatar
Check your brake lines. Old soft rubber lines can cause uneven braking.
Jamie79SC
Old 02-03-2005, 10:51 AM
Thanks Jamie - the pull is not during braking but during regular driving -
Bill
Old 02-03-2005, 10:54 AM
Send a message via AIM to NoLift911
Warped rotors will not cause a car to pull. The most you will notice is a pulsation in the pedal.
You either have an alignment issue (still) or a bad tire.
Have you tried swapping tires on the front to see if there is a difference? Are your tires feathered or cupped? Even if the alignment and corner balance is accurate a tire can cause a pull.
Even new tires can cause a car to pull to one side or another if there is a bad belt or an odd tread pattern that does not agree with the car.
-Jeff
Jeff
Old 02-03-2005, 10:55 AM
Jamie79SC's Avatar
oops - Looks like I didn't read your post closely enough...
Jamie79SC
According to the 911 alignment handbook I have if the rotor is rubbing on one side during driving it will cause the car to pull to that side - makes sense to me?? The tires and wheels are brand new, the tie rods and ball joints are near new, and I believe the car is pretty close on the corner balance. I am going to replace the rotors, but perhaps it will not make a difference.
Bill
Old 02-03-2005, 11:01 AM
Super Moderator
cstreit's Avatar
I would try swapping tires as a cheap check first.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-03-2005, 11:44 AM
Thanks Chris - the tires are brand new and it did this even before I put them on (the old tires were brand new as well). I want to change the rotors out anyway so no big deal there.
Bill
Old 02-03-2005, 12:26 PM
I think you are misunderstanding the handbook...
If it is anything related to brakes it is that you have a caliper dragging not the fact the rotor is warped. The two actually go hand in hand as in if you have a sticking caliper or it is dragging (meaning that the caliper is applying braking force on it's own on that wheel and you are not at the pedal) that will warp a rotor.
So the rotor may be warped but that in itself is not causing the pull. I would check your front calipers, slides, seals pads etc.
Are you doing this alignment/corner balance yourself?
-Jeff
Jeff
Old 02-03-2005, 01:29 PM
same exact thing a couple months ago, i posted a picture as well. A rebuild on the calipers fixed the whole thing
new rotors= uneven wear pattern
Old 02-03-2005, 02:42 PM
Bill Verburg's Avatar
Have you checked cornor weights? and Alignment?
Bill Verburg
Old 02-03-2005, 02:51 PM
wastintime's Avatar
Send a message via AIM to wastintime
guys, i'm really sorry to hijack this thread, but I have a question I think only zcat3 can answer... zcat if you can check your PMs I'd appreciate it, I sent you a link to a thread on the 911 board.
-Andy
'67 912, '92 C2, and '93 RSA - all gone
Old 02-09-2005, 10:56 PM
schleg79's Avatar
jbrinkley's post above sounds convincing. But, you say you adjusted your ride height recently? I monkeyed with my ride heights and spent the next 3mos with the same problem. My car's pull to the right wouldn't go away even after 2 alignments with near perfect specs. Finally, I was convinced by a member on this board that my corners were out of balance.
My home remedy to check the theory: I raised the front right ride height a bit to "throw" some weight left/aft and it was remedied - straight as an arrow.
If it's not the brakes, you'll definitely be good once you can get it in for that cb and alignment...
78 SC Coupe Silver
79 SC Coupe GP White - sold
Old 02-10-2005, 05:02 AM
RETIRED
Joe Bob's Avatar
A hanging piston in a caliper due to a bore issue or a swollen line will cause a pull as will an alignment issue....
Do you have a pyrometer? Drive the vehicle for ten minutes and shoot the temp of the front two rotors. If one is signifcantly higher in temperature you have a hanging piston...R&R the brake system.
When was the last time the brake system has been inspected and serviced with fresh brake fluid?
2012 ML350 3.0 Turbo Diesel
Old 02-10-2005, 07:40 AM
