"competent reupholstry" probably wouldn't be me doing it in my garage. But I think I may give this a shot.
"Rust never sleeps" |
Registered Loser
Dave, that is supreme. Thanks for sharing the pics and info. Don't be surprised if the day comes soon when you can spot a Pelican car by the ultrasuede on the dash cap.
Owner of a wrecked 944 Last edited by Wrecked944; 03-09-2005 at 06:14 PM.. |
"Rust never sleeps" Last edited by MikeSid; 03-09-2005 at 02:45 PM.. |
update on my hairliner
tomorow the dash & door arm rest
X/A |
So when you were done were you tempted to lay on your back in your seat and walk barefoot on your headliner - I would have been
![]() That looks GREAT!
Thanks Todd I drank what? = Party out of bounds - PriceLESS - BudWIZER "Boy Im gonna burn you a new one! - A new what officer?" = night in jail 993'ish Widebody bastardo http://hypertec.ws/todd_porsche/photos/
Wow! Headliners also. Looks awesome YellowBird.
We need to move these posts and make a "ultrasuede" thread. |
Maybe just a general "pimpin' my ride" thread
![]() yello-bird, that looks great. Makes my dash job look like a spark plug job compared to a 915 rebuild
dave 1973,5 |
Pimpin' ? The 997 has an alcantara headliner ;-) And it's the car's best feature too ! I am all for this ! Did you make the headliner by stitching pieces together ? Template ?
This is all very cool. Maybe I should fix my temps gauge first but I like this thread ! |
an up-date
X/A |
Wow, color-coded stitiching??? Now that's stylin'
![]() Looks great. Did you do it yourself? Nice job! Very even stitiching. Guess that was a way to go for me too, but after I finished re-covering my seats I quickly returned the sewing machine back to the store
dave 1973,5 |
I'm impressed with the workmanship!
Let me ask the collective, though. Is the contrast between the vinyl on the dash and the ultrasuede too stark? Like them or not, the Dash Cap sort of blends in with the factory dash. Once upholstered with ultrasuede, the contrast is obvious. Thoughts?
1984 Targa |
It's a bit darker under the dash, so the un-upholstered part isn't as glaring, and besides, my dash top, and every one elses, was smooth (leather I think... maybe vinyl) while my dash panel is basketweave. I don't think anyone ever thought that they don't match even though the texture is different.
I haven't gotten around to it but I will post some pics later. In my opinion, the difference "disappears" and isn't noticeable.
dave 1973,5 Last edited by }{arlequin; 03-14-2005 at 02:13 PM.. |
Could this whole procedure be done with a good quality full grain leather, it might look better than original that way? Biff
I've seen recovers done with the vinyl that has the *exact* grain cast into the factory dash. So it's definitely out there.
As a veteran of several 'dash top' coverup installs, I have to warn that they will warp badly over time. And if you use the silicone adhesive inconsistently, the shell will expand where it's *not* stuck down, making the warping potentially ugly. but at 1/10th the cost of a new dash (uninstalled) maybe replacing the dash cap can be considered maintenance.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
I re-roofed a flat rubber roof section of my home last fall and used some really strong industrial contact adhesive. If that stuff can take direct sun year after year for 20-30 years I would think it could hold down a piece of vinyl or leather for a while. What do you think? Biff
Biff, use a lot of it, uniformly under the entire area, and I bet it'll essentially be permanent.
I've gotten a dash top following this post and I gotta say the fit is impressive ! In seconds my car went to multiple cracks dash to smooth ! it's not the same material, it's a toupee alright, but I kinda like it ! The only thing - not reported above - is the fit is so-so where the air vents are. You have to remove the plastic air vent covers fo ra good fit and then you have those ugly metal slats visible... But overall, for $80, I'd recommend one !
"appearance update"
dave 1973,5 |
Looks like it's holding up well Dave
MMMMMMMMMMMMMmmmmmmmmmmmm..............
Me likes that dash alot }{arlequin!! |
