Jerry S's Avatar
930 with SC cam ??
What type of gains can you get from changing stock 930 3.3 L cam profile with an SC grind camshaft ???
Keeping in mind that my other mods are only a K-27 and a single outlet PowerHaus muffler and stock exchangers. The car is Canadian (ROW = 300 HP stock)
Thanks Jerry S
Old 02-18-2005, 03:07 PM
better low end response. like now, when you take off from a stop, or try to accelerate from 30mph in 2nd, there ain't a whole lot of pickup for a while.
206 637 4071
Old 02-18-2005, 03:10 PM
Jerry S's Avatar
what type of cam would be the best match for a K-27 1100.
is there a horsepower number that could be associated with the SC ???
Old 02-18-2005, 03:16 PM
Crotchety Old Bastard
RarlyL8's Avatar
I have SC cams in my engine. Difference is dramatic. The turbo 3.3L lays down MORE torque now than the modded 3.0L SC engine it replaced. Maked for excellent driveability. Torque is good.
A 930 engine with K27, SC cams, aftermarket or Euro exhaust, and larger intercooler should put down HP numbers close to 400. A search on the topic should verify that number. The formula is tried and true.
Old 02-18-2005, 06:35 PM
pjv911's Avatar
Send a message via AIM to pjv911
Would an improvement be found using SC cams in a 92` 3.3 turbo ? I guess you would call them 965 cams .
Kurt Williams
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 02-18-2005, 06:41 PM
Send a message via Yahoo to Lukesportsman
Are you sure your tools fit post 73 Porsches, Kurt? I know you have some modern wrenches for the Z, but it seems kind of out of your character to work on Porsches with rubber bumpers Or are you refering to the 69' with the retrofitted engine?
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 02-18-2005, 08:53 PM
Jerry S's Avatar
what would the best cam be to put in for the most power assuming an otherwise stock configuration ?
And is it still relatively still street driveable?
Thanks Jerry S
Old 02-20-2005, 04:19 PM
pjv911's Avatar
Yes you are correct . Its a 69` with the c2 turbo engine . Good eye.
Kurt Williams
Old 02-20-2005, 04:39 PM
